Author Topic: Pescara centre caps  (Read 6386 times)
Offline Shabba168
Pescara centre caps
« on: November 18, 2012, 12:51:27 pm »
Does anyone know what size centre caps they need might get vw ones but fancy BBS caps
Or does anyone have any
Offline Mk5 GTian
  • -Receive: 37
Re: Pescara centre caps
« Reply #1 on: November 18, 2012, 12:53:52 pm »
Unfortunately you can't get them. I've been down this road before. I've got VW ones on my Pescy's.
  • -Receive: 427
« Reply #2 on: November 18, 2012, 02:44:37 pm »
There are no genuine BBS caps that will fit on the Pescara's strange as that seems.  :sad1:
Price of a set of VW caps is about £30 and Size is 65mm outside and 55mm inside IIRC. Pretty sure part number your after is....
 3B7601171XRW
Offline Shabba168
« Reply #3 on: November 18, 2012, 08:45:58 pm »
Are these not BBS VZ like the link below with bbs centres
http://www.wheelbasealloys.com/18_Inch_BBS_VZ_Titanium_Alloy_Wheels__3164
Offline Shabba168
« Reply #4 on: November 18, 2012, 09:04:48 pm »
I believe I have the VZ anyway as I have the 8j x 18
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: November 18, 2012, 09:06:34 pm »
did you buy the other set of wheels from the A4 pescaras that i linked?
those don't accept the BBS centre caps either. the part number above is correct
PLANS: Stage 2+
Offline wilmott1980
« Reply #6 on: November 18, 2012, 09:08:12 pm »
I need some center caps too. :laugh:
Offline Shabba168
« Reply #7 on: November 18, 2012, 09:17:18 pm »
Yeah I bought the other set.
I thought they were identical to the VZ which have the BBS centre cap
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #8 on: November 18, 2012, 09:24:54 pm »
not quite. the A4 set is made by BBS for Audi, but it is an Audi part. you can only buy them new from Audi, not from BBS. the offset is slightly different (ET43 for the Audi, ET44 for the VZs). the style is very similar though.
as above, only VAG centre caps will fit. if you have Monzas at the minute your centre caps are a straight swap.
PLANS: Stage 2+
Offline Shabba168
« Reply #9 on: November 18, 2012, 09:31:45 pm »
Cool cheers
Offline Shabba168
« Reply #10 on: November 21, 2012, 04:08:01 pm »
The above part number centre caps are the same as my old monza wheels and they clip in but they are loose in the hole and can hear them rattle at low speeds any other centre caps that fit?
Offline Shabba168
« Reply #11 on: November 21, 2012, 10:22:46 pm »
Please help if someone could get the part number off there caps would really help
  • -Receive: 427
« Reply #12 on: November 21, 2012, 10:31:52 pm »
Part number on my Edition30 centre caps are 3B7 601 171, I've just checked for you as there in a box in the cupboard. I replaced them with the newer ones I listed before.
Offline Shabba168
« Reply #13 on: November 21, 2012, 10:52:20 pm »
Hmmm that's same as mine.
The last 3 letters are the colour code.
Maybe the I need the Audi ones to get it to fit
It clips in fine just it's loose when it's in it s position
  • -Receive: 427
« Reply #14 on: November 21, 2012, 10:56:01 pm »
I'd try an Audi dealer and find the correct size and go from there. At least you'd know the right size then. You may be able to find some VW caps (OEM or aftermarket) or even BBS (copies) to fit.
