Author Topic: xenon style lights by FK any good???  (Read 76187 times)
Offline Timvgti
Re: xenon style lights by FK any good???
« Reply #240 on: January 31, 2013, 04:01:29 pm »
Thanks 'Mo'.
I used a slim ballast Infinity 55w kit in my stock halogen headlights with those plastic ring xenon adapters for the golf 5 halogen housings (maybe there was the problem, cause they felt dodgy). There was a small black box on every cable, so I guess those where built in resistors for the infinity hid kit. I also activated xenon without shutters with vagcom.
Worked for a out 4 months, then the wiper motor failed...
So I'm not sure if I dare to get a hid kit again.
Maybe I just put Osram Nightbreakers or other 6500k h7 bulbs in my the new xenonlook housings, so they look like xenon, but nothing can go wrong...
Offline mo
« Reply #241 on: January 31, 2013, 04:19:30 pm »
Do you use coming / leaving home lights ?
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline Timvgti
« Reply #242 on: January 31, 2013, 04:43:26 pm »
Yes I do...
Offline mo
« Reply #243 on: January 31, 2013, 04:51:13 pm »
Sorry Tim i meant to say did you use coming / leaving home lights when you had the hid kit fitted ?
RNS510 & MDI
Offline Timvgti
« Reply #244 on: January 31, 2013, 04:56:30 pm »
Yes' I had CH and LH activated (always had, because I like this feature).
Offline mo
« Reply #245 on: January 31, 2013, 05:53:47 pm »
Im wondering if this may be an issue. May disable mine in the meanwhile.
I dont think the small black boxes were resistors they are just the bits that cant fit in the slim ballast.
« Last Edit: January 31, 2013, 05:56:01 pm by mo »
RNS510 & MDI
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #246 on: February 02, 2013, 07:39:57 pm »
Finally got mine in:
My brother has bullied me into fitting a 35w HID kit into them. Why does the wiper motor fry if you have HIDs? Will i have any problems? Iv also not changed any coding?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #247 on: February 02, 2013, 07:52:04 pm »
And what sidelight bulbs are people using? My current ones are pants!
Offline mo
« Reply #248 on: February 02, 2013, 09:37:06 pm »
Apparently the lights and the wipers share a common power feed.When you use hid's with capacitors on them any excess voltage stored /created by the capacitors (not entirely sure which) but this voltage ends up frying the wipers.
I have a standard 35w non canbus friendly digital set of hid's and have coded my car for xenons no shutters.Seems to work fine so far but will update of any changes or fried wipers.
RNS510 & MDI
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #249 on: February 02, 2013, 09:40:20 pm »
I think mine may be canbus friendly but i will have a go at coding them in aswell
Offline mo
« Reply #250 on: February 02, 2013, 10:19:38 pm »
If yours has capacitors coding will not prevent any damage to your wipers unfortunately.Unless you have the removable type of capacitors.
like these http://www.ebay.co.uk/itm/2x-HID-Xenon-Canbus-Warning-Light-Error-Canceller-set-/330803508480?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d056cf500
« Last Edit: February 02, 2013, 11:01:54 pm by mo »
RNS510 & MDI
Offline Timvgti
« Reply #251 on: February 03, 2013, 08:40:01 pm »
I fried my wipermotor with a 55w infinity h7 hid set (this set didn't have capacitors and I coded vcds xenon without shutters). Worked perfect for +/- 4 months, them wiper motor suddenly failed..
This week I finally receive my FK xenon style headlights, but still not sure to fit a hid kit or just out 6500k H7 bulbs (like osram nightbreakers) in...
Offline apples12
« Reply #252 on: February 03, 2013, 11:08:13 pm »
fried two wiper motors until some research led me to discover it could be the ballasts i was using with the hella celis headlights sitting on top of my wardrobe! it is possible to retrofit OEM ballasts and bulbs into the wiring that way you know you've got a good set of bulbs and ballasts...
just got to get hold of a pair of ballasts and bulbs and figure out the +ve/-ve feeds and bobs your uncle. i had it on mine for a short while. www.hidplanet.com thats where you'll find many pinouts.
i'd highly recommend staying away from the cheapo ballasts.
MK6 GT TDI  - CW - LUX pack
GONE
Offline Timvgti
« Reply #253 on: February 04, 2013, 01:49:38 pm »
Received my Depo xenonlook headlights today (The Netherlands).
It was very well packaged (double boxed).
Quality is excellent! Looks like o.e.m.
I am very pleased with them and I am glad I decided to buy these new headlights in stead of second hand o.e.m. xenons (looking at price, the fact that they are new. Unscratched, etc.)
Still not sure if I'm going to install a hid kit to them, before installing them (next weekend)...
Looking at the recess on them bottom (the place where the o.e.m. ballast also goes when you have factory xenons), it looks like a good place to install an aftermarket slim hid ballast. You can also drill al hole there and feed the wires from the ballast into the housing/h7 xenon bulb, using a robber grommet. Thus you don't need do drill a hole in the plastic round cap on the back of the housing.
(see picture 4)
Who can give me link to a aftermarket 35w hid kit that 100% won't fry my wiper motor (again...)?
This is the 55w infinity kit I custom made in 2011. I used it in the stock halogen gti headlights. Worked for about 4 months, then it killed the wiper motor (I've thrown this hid kit away immediately).
« Last Edit: February 04, 2013, 01:57:03 pm by Timvgti »
Offline mo
« Reply #254 on: February 04, 2013, 02:43:41 pm »
hmm, this could be an idea.
Would need some of these http://www.ebay.co.uk/itm/H7-to-D2S-D2R-Adapters-for-Philips-Osram-Xenon-HID-Bulb-/270354512667
RNS510 & MDI
