Author Topic: xenon style lights by FK any good???  (Read 71368 times)
Offline mtj2k
  • 1.4 TSi GT
Re: xenon style lights by FK any good???
« Reply #315 on: February 20, 2013, 01:32:50 pm »
does anyone know which way up the bulbs are in OEM xenons? i'll have a play with mine when i get them....
Offline Luka
« Reply #316 on: February 20, 2013, 08:16:09 pm »
Wire at 6 o'clock.
Sold - 2006 Tornado Red GTI 3dr
Offline mtj2k
  • 1.4 TSi GT
« Reply #317 on: February 20, 2013, 09:11:44 pm »
Looks as if the Hella version have already thought of this:
Offline Timvgti
« Reply #318 on: February 25, 2013, 10:13:30 am »
Next week I can use my dad's Dremel tool, so I'm going to mod the H7 xenon bulbs (make a tab on the other side), so I can place the 180 degrees rotated in the Depo projectors.
Anybody else already tried it to solve the shadows?
Offline mtj2k
  • 1.4 TSi GT
« Reply #319 on: February 27, 2013, 02:19:01 pm »
Tim - Let us know how you get on with the "6 o'clock" mod..
In other news - I found some interesting info on the transport office website regarding HID Kits. look here http://www.transportoffice.gov.uk/crt/doitonline/bl/mottestingmanualsandguides/mottestingmanualsandguides.htm So far, everyone has told me if that if you want to fit HID bulbs then you will need an autolevelling system and headlight washers to pass an MOT. The wording on the published MOT guidance seems to oppose that.
Copied from that page^:
Information
Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.    Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems.  In such cases, the benefit of the doubt must be given. Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch.
Method of Inspection
Where HID or LED dipped beam headlamps are fitted, switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
Reason for Rejection
A headlamp levelling or cleaning device inoperative or otherwise obviously defective.
Your views on this would be appreciated thanks!  :happy2:
Offline jimbob001
  • 2.0 GT TDI
    • Ma5da Racing
« Reply #320 on: February 27, 2013, 03:38:38 pm »
Hi
I bought some r32 look headlights from euro wagens ltd on ebay for £250 all in, they are a proper upgrade set, they fit perfectly and plug and play!! link is below -
http://www.ebay.co.uk/itm/Xenon-look-head-lights-lamps-VW-Golf-MK5-GTI-Jetta-Genuine-Hella-UK-RHD-/250900458319?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a6ad52b4f
Please ask any questions.
Offline mtj2k
  • 1.4 TSi GT
« Reply #321 on: February 27, 2013, 04:27:51 pm »
Hi
You linked to the Hella ones, i think the ones you got are the DEPO ones if you only paid £250!? Still look great though! get some pics up when you've installed ;)
Offline Timvgti
« Reply #322 on: February 27, 2013, 05:50:15 pm »
Did the 6 o'clock mod yesterday. Easy with a dremel-tool.
The two ground shadows are completely 100% gone!!!
I will make a picture ASAP.
First going to take it to a garage that can adjust the lights properly, because I think they are aimed a little to much to the right (I have a lhd) and on that right side, I see a little brighter spot on the ground so guess the right projector is projecting a little to much an the ground on that spot.
Rest of the beam is now 100% as it should be!
No shadow stripes like I posted earlier (the photo).
Offline jimbob001
  • 2.0 GT TDI
    • Ma5da Racing
« Reply #323 on: February 28, 2013, 10:11:03 am »
Hi
If you phone the guy up he gives discount and photos below.
Sorry about how dirty the car is  :sad1:
« Last Edit: February 28, 2013, 10:23:14 am by jimbob001 »
Offline mtj2k
  • 1.4 TSi GT
« Reply #324 on: February 28, 2013, 10:47:17 am »
They look great! well done  :happy2:
Offline Timvgti
« Reply #325 on: February 28, 2013, 08:34:13 pm »
As promised, here the before and after 6 o'clock mod pictures:
I quess I don't need to tell you guys which photo is with the 6 o'clock mod  :grin:
Looks so much better now! No two ground shadow stripes anymore.
Offline Kalpsn2000
  • -Receive: 56
« Reply #326 on: February 28, 2013, 09:39:12 pm »
So you did a 180 with the wire going from the top to the bottom?
Offline mo
« Reply #327 on: March 05, 2013, 03:52:09 pm »
Bought a second set of HID bulbs (this time 4300k) and did the 6 O'clock mod on them.Will fit em tomorrow and see how i get on.
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline Timvgti
« Reply #328 on: March 05, 2013, 06:01:57 pm »
Yes  I did and  I used a dremel to cut the new tabs on the other side of the steel bulb-ring.
Offline mo
« Reply #329 on: March 05, 2013, 06:45:31 pm »
Same method i used
RNS510 & MDI
