Author Topic: Anyone replaced the auto light/wiper sensor??  (Read 1308 times)
Offline acme
« on: November 20, 2012, 06:23:55 pm »
Evening all,
Anyone replaced the sensor for the lights/wipers on the back of the interior rearview mirror? Got a price from the main stealer which wasn't as bad as I thought but wondering if it's a DIY, i.e. is it simply a case of plugging it in?
Also does it need aligning/setting up to the ECU etc, or is it simply a case of plug & play?
Mine's an early MKV so about 6-8 sensors round the outside with one in the centre - presumably for the wipers. Seems later ones are four diamonds in two rows of two - not sure this makes any difference??
Any suggestions/help appreciated.
Offline brough74
Re: Anyone replaced the auto light/wiper sensor??
« Reply #1 on: November 20, 2012, 07:31:46 pm »
How much was the quote if you dont mind me asking. Mine has the 4 diamonds and im sure its way to sensitive as the lights seem to be on most of the time
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: November 20, 2012, 08:02:10 pm »
easy to change, any version can be fitted
remove the shell trim
and slide downwards to the bottom of the windscreen
unplug the plug
Cluster and Key coding
Location Great Yarmouth
Offline Veee-dubber
« Reply #3 on: November 21, 2012, 06:27:09 pm »
How much were you quoted pal? Auto setting on my wipers doesn't work so thinking about changing the sensor
Offline acme
« Reply #4 on: November 22, 2012, 10:44:38 am »
£38.20 incl VAT from the main stealer - which was less than I thought - then again once I get it it'll probably look way over priced!
Before replacing consider looking at other Golfs. I've had mine 4+years and they are VERY sensitive - during low light levels of winter they're on almost all the time in my experience.
Offline swgti
  • -Given: 28
« Reply #5 on: November 22, 2012, 11:00:27 am »
I've found that on my 05, had to turn them off the other day because the person in front must have thought I was mad the amount of times they were going on and off.
Offline acme
« Reply #6 on: November 22, 2012, 12:16:02 pm »
On a sunny winters day like today if I start off in the shade the lights are likely to be on and take quite some while to turn off, even if driving into direct sunlight - surely this can't be right? I do think it's worse than it use to be, hence why for £38 I think it's worth replacing the sensor - though it may make no difference!
