Author Topic: Diverter Valve Version/Part Number/Price?  (Read 8590 times)
Offline Kalpsn2000
  • -Receive: 56
« on: November 21, 2012, 03:05:08 pm »
I am looking at REVO stage 1 so want to update my diverter valve.
Firstly, which version should I go for?
What are the part numbers?
What is the new price from the stealers?
« Last Edit: November 21, 2012, 03:19:53 pm by Kalpsn2000 »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=j7ugv894vth7vdg2ka7s0l5uss&/topic,19740.0.html
Re: Diverter Valve Version/Part Number/Price?
« Reply #1 on: November 21, 2012, 03:09:23 pm »
06F 145 710 D
As you are on a GTI 200PS, i would advice you get a piston type one.
Offline GTI-Ross
  • Learning All The Time :)
« Reply #2 on: November 21, 2012, 03:17:25 pm »
What in the new price from the stealers?
Yeah im in the same boat....i would also like to know which is best and how much they are.....Link anyone?
Offline Kalpsn2000
  • -Receive: 56
« Reply #3 on: November 21, 2012, 03:22:40 pm »
06F 145 710 D
Thanks Rich
Any idea on price at the stealers?
« Reply #4 on: November 21, 2012, 03:23:43 pm »
Cant remember exactly... but 40-50 quid!
Offline swgti
  • -Given: 28
« Reply #5 on: November 21, 2012, 03:30:49 pm »
Awesome do the revised type (G?) for a decent price £45ish IIRC.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #6 on: November 21, 2012, 03:39:40 pm »
D on a gti due to heat
G on an Edition 30
Diesel Daily Hack.
Offline GTI-Ross
« Reply #7 on: November 21, 2012, 04:02:44 pm »
  • -Receive: 427
« Reply #8 on: November 21, 2012, 04:08:19 pm »
Would go for the G valve as it seems to hold boost better, get it for the VW main dealer of TPS if I were you.
Revision G Part Number 06F 145 710 G about £40
Revision D Part Number 06H 145 710 D about £55
  • -Receive: 427
« Reply #9 on: November 21, 2012, 04:10:57 pm »
Is it this one?
http://www.awesomegti.com/car/vw/golfmk5/oem-2-0t-upgraded-piston-diverter-valve
That's the piston type one, the Revision D (06H 145 710 D)
Offline swgti
  • -Given: 28
« Reply #10 on: November 22, 2012, 07:10:29 am »
Is it this one?
I thought the upgraded one was the G - Piston type and the old version was the D - diaphram type  :confused:
« Last Edit: November 22, 2012, 10:18:49 am by swgti »
Offline donovan2123
« Reply #11 on: November 22, 2012, 10:02:14 am »
From what I can gather Rev G is for ko3 and rev D is for ko4. The old G for ko4 has been replaced by D.
And rev C to Rev G for ko3
Offline Kalpsn2000
  • -Receive: 56
« Reply #12 on: November 22, 2012, 10:46:30 am »
Getting confused now!
I will be going to the stealers at the weekend to see what they say/have.
  • -Receive: 427
« Reply #13 on: November 22, 2012, 11:09:19 am »
^^^^ G for K04 Turbo'd cars (Edition30/Pirelli) and D for the K03 Turbo'd cars (GTI). Both would be better than the Revision C though.
Offline 56OctyVRS
  • -Receive: 72
« Reply #14 on: November 22, 2012, 11:09:47 am »
Hope to clear things up for you.
The Revision C was prone to splitting and has been replaced by the G revision.  The early G revisions had a few that split but they released a newer G revision that is more robust and so far none that I know of have failed.
When the C revisions were failing people (including myself) went to the D as it was the best solution on the market at the time. Some went the Forge DV route but for a simple plug and play the D was the best.  Now the D revsions have been known to leak, as was proved by RTech Nick. The end of the piston does not have a rubber seal so air can leak by, whereas the G revision has a seal on the end and makes a better seal.  The G is designed for both the K03 and K04 GTi variants.  The D is from the Audi S3.
Just to confuse you the D has now been replaced by a new C revsion, which is basically a D without the cage around the piston.
Which one to chose will be up to you, as people swear by which ever one they have fitted. Having had the D and G fitted I prefer the G, as the car runs smoother and feels more powerful throughout the rev range.  Plus its cheaper by quite a bit and cars running 340bhp are running the valve without any issue.
Hope this makes it a bit clearer for you  :happy2:
