Author Topic: New look polar fis+??  (Read 3774 times)
Offline RoMocop
Re: New look polar fis+ ??
« Reply #15 on: November 27, 2012, 01:42:00 pm »
Right, the cage thing that holds the gateway in place, does that move at all or does it stay put?
Offline Baz300
« Reply #16 on: November 27, 2012, 02:52:53 pm »
Can you not just disconnect the plug from the Canbus leaving the unit in place?
That's what I'm going to try and do tonight as I had so many cuts on my hands last time I swapped over the Canbus
« Reply #17 on: November 27, 2012, 02:54:52 pm »
I left it in place!  I first turned the gateway throught 90 degrees then just wiggled it down below the cradle.
Eddie_NL moves the entire cradle but I have no experience of doing it that way.
« Reply #18 on: November 27, 2012, 03:00:17 pm »
The cabling plug to the gateway has a lock on it securing it to the gateawy.
Trying to press the tab to release it ( it's oreintated at the top side of the plug) to remove the cable is near on impossible with the limited space available.
Offline RoMocop
« Reply #19 on: November 27, 2012, 03:45:19 pm »
Ok I have managed to move the gateway out of the cradle but I dont seem to have any room to move the gateway past the cradle in any way. I think I am stuck now so I will have to ask Eddie how I can remove the cradle. My hands feel like I've been ten rounds with Mike Tyson. :sad1:
Thanks for all your help. :happy2:
« Reply #20 on: November 27, 2012, 03:52:15 pm »
Did you try turning the gateway 90 degrees anti-clockwise then try to wiggle it down the right side of the cradle?
Offline RoMocop
« Reply #21 on: November 27, 2012, 04:04:20 pm »
I tried to wiggle it down from the back left hand side rather than bringing it forward. I think that must be where I went wrong, and now I cant get it back. :ashamed:
Cheers again for your help by the way.
Offline Baz300
« Reply #22 on: November 27, 2012, 06:07:54 pm »
I  Managed to get the plug off without removing the canbus
All pluged in and I get the polar fis screen
But when I try to set up any of the screens I just get a message saying " finding available parameters" and it won't do anything after that (left it 10 mins)
« Reply #23 on: November 27, 2012, 06:16:07 pm »
I would first double check that all the cables are securely connected.
Do you have a red or white mfd?
« Last Edit: November 27, 2012, 06:17:47 pm by bacillus »
Offline Baz300
« Reply #24 on: November 27, 2012, 06:19:40 pm »
I have double checked that everything is secure
I can get the engine rpm, battery voltage, coolant temp and outside temp working on screen 1 (must be factory settings on the polar)
 Tried dissconectIng the battery again but it's still the same
Offline RoMocop
« Reply #25 on: November 27, 2012, 06:26:32 pm »
Make sure all of your doors are closed use your key to lock and then unlock. This worked on mandys car.
« Last Edit: November 28, 2012, 12:09:13 pm by RoMocop »
Offline RoMocop
« Reply #26 on: November 28, 2012, 12:07:09 pm »
After round 3 of my battle with the Polar FIS I managed to plug it in.
Question is how do I select which parameters I want showing on the 5 pages?
It just looks like this at the moment:
Also, is it essential to finish off by doing the following via Vcds?
Quote
When you have finished to mount all the pieces, use a diagnosis software as for example Vag- com or another similar and follow the following steps:
-Connect with the 19-Gateway control module.
-Within this module, access to Installation list .
-Mark the module [75] Telematiks.
Finally, make an Auto-Scan or review the rest of modules of your vehicle in order to erase the errors that have been generated because of disconnecting the battery and remove the connector of the vehicle Gateway.
« Last Edit: November 28, 2012, 12:08:41 pm by RoMocop »
Offline Baz300
« Reply #27 on: November 28, 2012, 12:10:19 pm »
Hold down the ok button on the steering wheel then it will take you to the polar menu
I think it is in screen press ok then screen 1 press ok and it will say parameter1. Parameter2 etc
Select the one that you want to change and press ok
That's as far as I got
Offline RoMocop
« Reply #28 on: November 28, 2012, 12:14:09 pm »
Cheers mate I will have a look. Any more news on yours yet?
Offline Baz300
« Reply #29 on: November 28, 2012, 12:18:17 pm »
I can't update the firmware from work as I don't have admin rights on the computers
But going to try when I get home tonight
