Author Topic: Skoda Octavia vRS TFSI - K04 in progress..  (Read 52639 times)
Offline Vasekk
    • OEMplus.eu
Re: Skoda Octavia vRS TFSI
« Reply #90 on: March 22, 2013, 09:35:57 am »
Wheels ready for season  :laugh:
Skoda Octavia VRS mk2 TFSI from Czech Republic powered by OEMplus.eu
Offline rob_e
  • 2012 vRS Octavia
    • vRS blog on Pistonheads
« Reply #91 on: March 22, 2013, 06:16:21 pm »
 :laugh:
Get them on!
Offline Vasekk
    • OEMplus.eu
« Reply #92 on: March 26, 2013, 08:50:08 am »
I have posibility to buy rear ceramic rotors 365mm from A7 (probably other audi models whare ceramic brakes are fitted). I would like to combine them with R8 like 8pistons calipes. I will make custom bells if needed. Do you think it may work together?
« Reply #93 on: March 26, 2013, 11:39:14 am »
I think you'd need ceramic specific calipers for those discs. IIRC the heat management is more critical for the cylinders in the calipers to protect the fluid from the higher temperatures generated by the discs and pads. R8 calipers would be okay if they were ceramic brake calipers, not sure you'd get away with normal R8 calipers designed for steel discs. DaveB is your man to confirm. :happy2:
Offline Vasekk
    • OEMplus.eu
« Reply #94 on: March 26, 2013, 11:43:21 am »
I found out that they cannot be used with R8 calipers because disc surface is too small.
Offline Vasekk
    • OEMplus.eu
« Reply #95 on: April 02, 2013, 02:37:25 pm »
Some news here... i have bought mint set of OZ Ultraleggera 8x18 ET45 for some track fun for 420£. 19" BT wheels were waxed and polished.. and i also get new ultralow car jack  :happy2:
Offline Vasekk
    • OEMplus.eu
« Reply #96 on: April 04, 2013, 03:11:47 pm »
I have just realised that last year i have replaced diverter valve G(which was originaly on car) with D. What is better?
« Reply #97 on: April 04, 2013, 04:21:24 pm »
I think you should be running a G.
The D is from the 1.4TSI and can cause problems of it's own.  :happy2:
Offline Vasekk
    • OEMplus.eu
« Reply #98 on: April 05, 2013, 06:38:30 am »
Ok i will try to swap them.
I am still not sure what remap to take. Next winter i would like to go for K04 rebuild. So now i am looking for normal Stage 2 remap. For K04 i would probably go for Revo or Apr. Problem is i am outside UK so only possibility is flashing tool or sending ecu.
Offline Vasekk
    • OEMplus.eu
« Reply #99 on: April 07, 2013, 03:41:48 pm »
Wheel job done.. waiting for center caps. Iphone do not handle black well  :sad1:
Offline vRSAlex
  • -Receive: 253
« Reply #100 on: April 07, 2013, 06:29:27 pm »
Looking good.  Are they facelift mirrors?
Follow AKS tuning on Facebook
Offline Vasekk
    • OEMplus.eu
« Reply #101 on: April 07, 2013, 06:47:24 pm »
Yes they are. Was fitted in factory already because this is almost latest prefacelift car produced
Offline rob_e
  • 2012 vRS Octavia
« Reply #102 on: April 07, 2013, 08:01:21 pm »
looks great with the new wheels on.
« Reply #103 on: April 07, 2013, 08:04:21 pm »
I like those wheels but I think the Oz's will look the business.  :happy2:
Offline Vasekk
    • OEMplus.eu
« Reply #104 on: April 07, 2013, 08:15:47 pm »
I have tested OZ's too but just 1mm clearance to calipers, grr. Will have to use my 3mm spacers what i use for winter BBS.
