November 19, 2024, 04:57:21 am
All Things Mk5
Technical Workshop
Which is correct ?
Topic: Which is correct ? (Read 1487 times)
big.el
Taking part
-Given: 0
-Receive: 0
Which is correct ?
November 25, 2012, 01:40:34 pm »
Looking for some alloys for my golf and I was just wondering which of these is correct
Just a bit confused
sub39h
Just look at my post count
-Given: 189
-Receive: 84
Re: Which is correct ?
Reply #1 on:
November 25, 2012, 01:48:51 pm »
well what Golf do you have? Mk4 - 5x100, Mk5 - 5x112, Mk6 - 5x112 as it says in the pictures you've posted. centre bore will be 57.1 for all 3, but if it's wider than this it doesn't matter much, you just need some spigots.
MODS
: '09 tail lights | TT vents | Bilstein B14 | RNS-E 2010 | AMI | AKS Tuning custom CAI | Titanium BBS VZs | NQS BBK | WALK | Autotech RARB | Bluemotion aero | Blueflame TBE | Autotech HPFP | MY11 Wing Mirrors | Bluetooth | S3 Intercooler
PLANS
: Stage 2+
big.el
Taking part
-Given: 0
-Receive: 0
Reply #2 on:
November 25, 2012, 02:00:53 pm »
Mk5 as per bottom picture
Sorry I meant the offset lol there saying different things.
sub39h
-Given: 189
-Receive: 84
Reply #3 on:
November 25, 2012, 02:15:04 pm »
then it depends on wheel width and what you want the car to look like
MODS
PLANS
: Stage 2+
big.el
Taking part
-Given: 0
-Receive: 0
Reply #4 on:
November 25, 2012, 02:27:56 pm »
I mean i want to know the offset boundries on the standard set up. Not every wheel with a 5x112 fitment will fit will it ?
sub39h
-Given: 189
-Receive: 84
Reply #5 on:
November 25, 2012, 02:45:55 pm »
no but the width of the wheel affects the offset choice. so for example, not all wheels with an offset of 42 will fit either
the standard set up is 7.5J ET51. this is the same as 8J ET57, 8.5J ET63 and 9J ET69 in terms of where the wheel face will end up in relation to the arch.
have a play on here. it'll probably answer your question, even tho i'm still not sure exactly what it is you're asking:
http://www.1010tires.com/WheelOffsetCalculator.asp
Last Edit: November 25, 2012, 02:53:20 pm by sub39h
MODS
PLANS
: Stage 2+
All Things Mk5
Technical Workshop
Which is correct ?
