Author Topic: Recommend Me a diagnostic scanner  (Read 717 times)
Offline Ashley g
    • Durward's Autoshop
« on: November 25, 2012, 05:45:54 pm »
I'll be opening up My own garage in the new year, and will need to buy some diagnostic equipment. I've been using a Snap On Solus Pro at work for the last couple of years, so will probably look at getting a second hand one myself. Before I do, does anyone recommend an alternative? Ive been looking at the Autel MaxiDas too. Has anyone had experience with these?
Any help would be much appreciated.
Cheers, Ash
2007 Edition 30, build number 30 - APR Stealth TBE - APR HPFP- APR stage 2 remap - Custom CAI - KW Clubsports - 10mm spacers on rear - VW Motorsport LSD, clutch & quick shift - A few poly bushes here and there!
*SOLD AND I MISS IT!! ANYONE SELLING A NICE ED30 PM ME* - UPDATE - I HAVE IT BACK!!!
Offline PDT
  • -Receive: 142
Re: Recommend Me a diagnostic scanner
« Reply #1 on: November 25, 2012, 09:16:55 pm »
The latest Delphi DS150 is awesome, so much stuff on it.
Have used most systems, apart from the Autologic system this is by far the best.
Offline gizmo68
  • We're here for a good time, not a long time
« Reply #2 on: November 25, 2012, 10:22:04 pm »
If you are going to specialise in anything VAG then VCDS is a must have.
VCDS HEX-NET & VCP owner (covers all VAG cars)
(PM me if you require VCDS or VCP coding or scanning in Kent)
