Author Topic: Most up to date Diverter Valve?  (Read 3170 times)
Offline john a
    • The Veneers Cover Band
« on: November 25, 2012, 08:52:05 pm »
Guys what is the latest revision Diverter valve?
I currently have a D, was under the impression that a G is the revised version less prone to potentially leaking (that the D may be) but read a post on another forum suggesting there was now a later Rev C - which I thought was the old one with the rubber diaphragm the D replaced.
Confused much? Answers on a postcard please!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Most up to date Diverter Valve?
« Reply #1 on: November 25, 2012, 09:01:53 pm »
For the TFSI engine G is the latest - it ran A-G. The "D" revision that people have used is actually from the TSI engine but still works on ours  :happy2:
To answer your question, the G is the latest and at the moment, the best OEM DV you can buy
There was a revised D model with a diaphragm, but tbh you can't go wrong with a G. If you car was a late 2007 or later it probably has the G anyway
« Last Edit: November 25, 2012, 09:03:31 pm by GrayMK5GTI »
Offline GTI-Ross
  • Learning All The Time :)
« Reply #2 on: November 25, 2012, 09:03:45 pm »
think this was covered yesterday mate, go back through post or search  :happy2:
Offline john a
« Reply #3 on: November 25, 2012, 09:11:30 pm »
Thanks Gray that's what I thought, but found some confusing info and wanted clarification.
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #4 on: November 25, 2012, 10:15:29 pm »
I've got a 2005 gti still with original diverter valve and no problems as far as I know. Would revision g even fit mine and if so would there be any improvement?
Offline Kalpsn2000
  • -Receive: 56
« Reply #5 on: November 25, 2012, 11:01:55 pm »
More info in my thread from a few days ago :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,56938.0.html
Offline gazon69
« Reply #6 on: November 26, 2012, 08:29:51 am »
yes
Offline john a
« Reply #7 on: November 26, 2012, 09:01:26 am »
Thanks for that link, didn't find that when I searched just a mixture of posts from August 2008 through to some time in 2010, all out of order.
That's very useful. I am interested to see if replacing my D with a G makes any/much difference.
Offline ianv5
« Reply #8 on: November 26, 2012, 09:57:36 am »
I think it would be worth checking your original DV, I can pretty much guarantee it will be split. I thought my 2005Gti was running fine but still checked it and was split!
Replaced with 'G' version no problems :happy2:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #9 on: November 26, 2012, 12:07:50 pm »
They are just later revisions of the same part so yes  :happy2:
« Reply #10 on: November 26, 2012, 12:20:26 pm »
Depending on how bad a split in the diaphragm is, you should notice a drop in performance.
Extra boost pressure from remapped cars is what can (randomly) cause a split. Back in around 2006 the best option was a Forge DV rather than keep on replacing the OEM and early VW revisions didn't solve the problem - My Forge is still going strong.
Offline swgti
  • -Given: 28
« Reply #11 on: November 26, 2012, 01:10:12 pm »
Anyone got the part No for the "G" version then?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2sb5cibh5m0ocopc1gbiv70jt6&/topic,19740.0.html
« Reply #12 on: November 26, 2012, 01:11:33 pm »
06H 145 710 G
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #13 on: November 26, 2012, 07:46:07 pm »
06H 145 710 G
Someone else has quoted 06F 145 710 G for the rev G part no. So which is the correct one, 06H or 06F?
Offline Kalpsn2000
  • -Receive: 56
« Reply #14 on: November 26, 2012, 07:58:10 pm »
06H 145 710 G
I would also like to know as in my thread it was quoted as 06F.
