Author Topic: Polar fis has f***ed my car (more faults now)  (Read 19709 times)
Offline Baz300
« on: November 27, 2012, 07:31:54 pm »
I installed a polar fis + advanced box to my car today
First of all when I tried to change the peramiters it hung on this screen
And didn't do anything after that
I was able to get the preset peramiters on screen 1
And set the Bluetooth menu
I tried dissconectIng everything and reconnecting to see if that worked
But I now have an airbag warning light and I can't access any of the standard menus that I had before on the mfd
Anyone had this issues or know how to fix them?
« Last Edit: December 01, 2012, 12:53:24 pm by Baz300 »
Re: Polar fis has f***ed my car
« Reply #1 on: November 27, 2012, 07:36:06 pm »
Had my connected and disconnect a few times  with no issues
« Reply #2 on: November 27, 2012, 07:49:10 pm »
When you disconnect your gateway and reconnect it you may see a multitude of vcds errors that don't reappear after clearing them. This may be happening with you.
As for the polar, if you press the ok button on your mfsw when on your first screen, do you get to the configuration menu? If the answer to the question is yes, scroll down till you reach update>press ok then click ok in the update screen (don't attach your laptop via usb cable when prompted to do so). This should reboot the unit and hopefully solve your polar problem.
Did you install the correct firmware? It's red_dot for a mk5 gti and ed30.
hth
Offline Baz300
« Reply #3 on: November 27, 2012, 07:52:22 pm »
hth
I installed the red dot firmwear
I only get the computer screen on my mfd now, have lost the audio and vw set up menu can't even get any polar menu up
The top of the screen where the time usually is is blank now too
« Reply #4 on: November 27, 2012, 08:01:14 pm »
Ok looks like you need more specialised help!
I suggest you join the Polar forum now and post your problem in full.  http://www.auto-polar.com/forum/forum.php
I'm sure mun the programmer for polar will see your post and offer a personalised service to fix your issue. He may want you to run their specific tool to gain more insight.
If you have access to vcds then posting up a full scan may also help sorting matters.
« Reply #5 on: November 27, 2012, 08:04:07 pm »
Just seen you've joined the polar forum so hope they can sort you out.  :smiley:
Offline Baz300
« Reply #6 on: November 27, 2012, 08:04:13 pm »
I joined the forum and posted the same on there
I don't have acess to VCDS
I have a diagnostic scanner on my bluefin so I will see if that finds any codes and cleares them
It's started bucketing down here now so I will hopefully manage to remove the polar box tomorrow to see if that makes any difference
Offline bakili
Re: Re: Polar fis has f***ed my car
« Reply #7 on: November 27, 2012, 08:07:04 pm »
I am about to install mine. Not sure now :-\
Sent from my GT-I9100 using Tapatalk 2
« Reply #8 on: November 27, 2012, 08:08:45 pm »
I think you'll find that most folk have no issues when installing the polar.  :smiley:
Offline RoMocop
« Reply #9 on: November 27, 2012, 08:11:35 pm »
Have you got the new black box?
Offline Baz300
« Reply #10 on: November 27, 2012, 08:12:09 pm »
Just a thought but I have a newer canbus module fitted to my car to prevent battery drain for the rcd510
Would that cause any issues?
Offline bakili
Re: Re: Re: Re: Polar fis has f***ed my car
« Reply #11 on: November 27, 2012, 08:16:31 pm »
Mine is basic polar fis black box.
Original canbus 2008 car.
I am just trying to get to canbus first
Offline RoMocop
« Reply #12 on: November 27, 2012, 08:20:15 pm »
Sorry i forgot you got yours from my Girlfriend mandy :stupid:
Offline RoMocop
« Reply #13 on: November 27, 2012, 08:33:59 pm »
I Hope you get it sorted :happy2:
« Reply #14 on: November 27, 2012, 08:40:47 pm »
The newer canbus shouldn't be an issue with the latest version 3.0 firmware as the previous beta had this in it's change list: Solved issues with gateways 7N0 907 530 x that causes a misfunctiones of Polar FIS and didn't activate telematiks module in the gateway
fwiw I'm using an old 1K0 907 530 F canbus gateway with my rns510 and have no battery drain issues.
