Author Topic: Which oil?  (Read 1982 times)
Offline Mr Savage
Which oil?
« on: November 28, 2012, 11:56:09 pm »
Hey all,
Just a quick question, my check oil level lights come up on the dash and requires a top up. I was told to buy 5W-40, which I did. Castrol Edge Fully Synthetic 5W-40 but now after looking on the Internet people seem to be saying 5W-30 is actually what I need, who is right?
Car is VW Golf GT TDI (Mark 5) (58 Plate)
Need to top it up first thing tomorrow so advice is greatly appreciated.
Oh it's also been serviced every 10,000 miles (approx) the last service had the "Longlife oil used" box ticked on "Yes" though?
« Last Edit: November 29, 2012, 12:05:31 am by Mr Savage »
Offline zerolag
  • Ass of Ennis
Re: Which oil?
« Reply #1 on: November 29, 2012, 01:07:03 am »
Eek, why is your check engine light on?  Check your oil regularly man :(
Either of those Full Syn Edge weights will be fine for top up.
Offline Mr Savage
Re: Which oil?
« Reply #2 on: November 29, 2012, 07:25:30 am »
Well that's the thing, I do check it every couple of weeks. The oil level is still between the min & max markers so I'm not sure why it's even coming on, had an oil change a month ago. Cheers!
Offline Grande_GTi
  • -Given: 41
Re: Which oil?
« Reply #3 on: November 29, 2012, 10:46:01 am »
wHat ever you do, dont use 5/40 thats for vehicle with no dpf
and its not meant for 2.0tdi engines
5w30 l3
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline zerolag
  • Ass of Ennis
Re: Which oil?
« Reply #4 on: November 29, 2012, 10:59:53 am »
5/40 really isn't going to make a difference for top up purposes.  Any oil is better than no oil.
Offline zerolag
  • Ass of Ennis
Re: Which oil?
« Reply #5 on: November 29, 2012, 11:01:09 am »
I wouldn't put much in then.  Probably a faulty sensor... do you have VCDS to reset it.
Offline paulw123
  • -Receive: 47
Re: Which oil?
« Reply #6 on: November 30, 2012, 02:31:00 pm »
5W30 is what you need (currently), 507.00 spec as well if you have DPF.
My light came on just the once and i check level quite regularly. My MK4 1.9gt tdi oil level never moved, but Mk5 seems to use a little more, so top-up might be necessary between services.
VW dealers in essex & suffolk are using shell helix ultra AV-L at the mo. Special AV grade for vw's. Comes in 5litres, instead of castrol 4L, £39 from moto-oil.co.uk delivered.
Offline Max99
  • White GTi owner
Re: Which oil?
« Reply #7 on: November 30, 2012, 02:42:23 pm »
sorry to jump on this thread, but what oil is right for a stock MK5 Gti ? (did do a search but didn't find a solid answer)
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Which oil?
« Reply #8 on: November 30, 2012, 05:36:13 pm »
any VW 504/507 spec oil. favourite seems to be Castrol Edge.
vRSAlex is quite fond of Millers Nanodrive however. it doesn't have the VW rating, but exceeds all of VW's criteria anyway
PLANS: Stage 2+
Offline andybon
Re: Which oil?
« Reply #9 on: December 02, 2012, 06:22:40 pm »
And anyone with a Costco card can get the Castrol Edge 5-30 fully synthetic for £23.99 for 4 litres instead of the £46.99 that Halfords charge. I found this out when I  went in to get some the other week!
How hard can it be?
