Author Topic: Anyone know what this sign is?  (Read 1222 times)
Offline Rustybear
  • -Given: 243
« on: November 29, 2012, 05:46:32 pm »
Tried loading photo cant do it. It's yellow with curvy sides and exclamation mark in middle of it with rough line underneath?
 I think it's to so with tyres but I'm away from home and ain't got access to the manual. Had two new fronts last week so should I take it back?
Offline Baz300
Re: Anyone know what this sign is?
« Reply #1 on: November 29, 2012, 05:58:28 pm »
Yeah it is the tyre pressure warning
Check that all your tyre pressures are ok then hold the button down below your ashtray and it will reset
If it is really cold the pressures will drop with the temperature so could be nothing wrong
This is the tyre pressure warning light
« Last Edit: November 29, 2012, 06:00:16 pm by Baz300 »
Offline GTI-Ross
  • Learning All The Time :)
« Reply #2 on: November 29, 2012, 06:32:09 pm »
reset to what tho? and if it drops the pressure, how does it regain it?
Offline RENNTAG
  • Premium Performance Parts
« Reply #3 on: November 29, 2012, 06:44:17 pm »
If your tyres are at the correct pressure, reset it to tell the car they are at the correct pressure.
Tyre pressure drops and falls tepending on the temperature of the tyre an the air inside it.
The colder it is the lower the pressure will drop and vise versa. This is why tyre pressures shoud be taken when the tyres are cold.
Offline woky
« Reply #4 on: November 29, 2012, 07:09:53 pm »
only the other day the same light came on in mine, i checked the pressure and 1 tyre had 17 and 1 tyre had 16. i would have thought the light would have came on much earlier than that ??  :surprised:
Offline Moz
« Reply #5 on: November 29, 2012, 08:01:31 pm »
If you get this light, just top up all your tyres and hold the button down after for 2-3 seconds, it'll beep and the pressure has been reset
Offline Lone_Par
« Reply #6 on: November 29, 2012, 08:20:15 pm »
Here was me thinking everyone read their manual after purchase! ;-)
Offline GTI-Ross
« Reply #7 on: November 29, 2012, 08:24:55 pm »
lol, not when you buy second hand....more time reading what parts will make my car go into beast mode  :driver:
