Author Topic: No boost  (Read 1088 times)
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
No boost
« on: December 01, 2012, 02:09:02 pm »
2 weeks ago felt a little pop when I boosted in 1st. Thougt DV gone, but car continued to boost ok. Today on the motorway the boost has suddenly gone completely. No EML's or smoke or anything.
I presume the pop was the initial split and it has opened up over the 2 weeks and now is completely torn? Rev C DV, 47k miles, stage 1 about 1500 miles ago.
Please tell me I'm right and the turbo itself hasn't blown?
PJ
'07 Red manual
Re: No boost
« Reply #1 on: December 01, 2012, 02:39:25 pm »
Sounds like the dv and very easy to check on an ed30.
Offline nezquick
Re: No boost
« Reply #2 on: December 01, 2012, 04:06:58 pm »
youd still get some boost even with a torn dv id check to see your boost pipes havnt popped off but also insoect the dv  :happy2:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: No boost
« Reply #3 on: December 01, 2012, 04:34:25 pm »
Hmmm wonder if it's the wastegate stuck open?
'07 Red manual
Re: No boost
« Reply #4 on: December 01, 2012, 05:27:26 pm »
Start with the things that you can easily check before thinking something exotic is up...  :smiley:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: No boost
« Reply #5 on: December 01, 2012, 05:38:25 pm »
^^^Quite right...my mind does tend to wander and expect the worst.
I had a sore throat a while back, went on google and deduced that I had Multiple Sclerosis! My sister is a GP and just laughed at me.
'07 Red manual
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: No boost
« Reply #6 on: December 01, 2012, 07:01:36 pm »
UPDATE:
Just went for a run and car back to normal, boosting really well. Any ideas? :confused:
'07 Red manual
Offline nezquick
Re: No boost
« Reply #7 on: December 01, 2012, 07:05:10 pm »
youd need to scan it to really know whats going on (within reason) just keep an eye on it and maybe over the weekend have a visual inspection of the hoses and dv
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: No boost
« Reply #8 on: December 01, 2012, 07:17:27 pm »
^^^Cheers Nez.
When you say hoses I presume you mean the ones from the IC? I'm not really clued up on turbo hoses so if you could tell me where to look? Hopefully I can check them from the engine bay and not have to get the axle stands out...
'07 Red manual
Offline nezquick
Re: No boost
« Reply #9 on: December 01, 2012, 07:42:04 pm »
im afraid you will mate, axel stands remove the under tray and the larger black pipe on the drivers side going to the ic check that and then check the hose on the passanger side going to the throttle body (comes from the ic into a metal tube) check the metal connectors arnt movinf or feel loose. when i went stage 2 my hose started to blow off from a dodgy connector. and then for th dv theres plenty of threads with images on where and what to look for :)
