Author Topic: Can you retro fit rear parking sensors  (Read 3262 times)
Offline itismebigd
« on: December 01, 2012, 03:26:56 pm »
Hi as above is it possible to retro fit rear parking sensors to my golf gti,and what is all involved ie is there a kit from the stealers will they need coding thank you in advance
Dougie :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Can you retro fit rear parking sensors
« Reply #1 on: December 01, 2012, 03:29:16 pm »
You have 3 options
Any aftermarket kit that uses the reverse light feed to activate
The dealer aftermarket kit, which is not cheap, also uses the reverse light feed
or the factory retrofit standard or Optical (probably the most expensive)
Cluster and Key coding
Location Great Yarmouth
Offline itismebigd
« Reply #2 on: December 01, 2012, 03:58:45 pm »
Thank you Edd,now to make up my mind which one of the two,as i dont have the rns 510 for rvc,unless there is a way off doing the rvc on the mfd2?lol
Dougie :happy2: :happy2:
Offline apples12
« Reply #3 on: December 02, 2012, 03:51:06 pm »
Hi,
is there anywhere which mentions the exact measurements for drilling the holes and/or does it have the markings on the inside of the bumper for where to drill through?
what would be the size of the holesaw required to retrofit OEM OPS?
MK6 GT TDI  - CW - LUX pack
GONE
Offline itismebigd
« Reply #4 on: December 02, 2012, 08:25:27 pm »
Very good question apples,im hoping edd could shine some light on this for us both :happy2: :happy2:
Offline Danielmoore
« Reply #5 on: December 02, 2012, 08:31:37 pm »
I just had a friend fit corbra ones for me as he works for richter and i think he done 6in from number plate then 12 of that sensor not 100% i can measure in the morning n let you know if u want too
Offline SI-R32
  • -Receive: 125
« Reply #6 on: December 02, 2012, 08:32:44 pm »
You would not want to use a hole saw it would tare the bumper and paint to spreads, I used a sharp 18mm max hole size step cutter that cut the paint perfect with no imperfections
Offline Danielmoore
« Reply #7 on: December 02, 2012, 08:40:44 pm »
Yh there perfect for the job such a nice cut with them
Offline Squeeguk
« Reply #8 on: December 02, 2012, 09:30:03 pm »
There are marks on the inside of the bumper where to drill and mount and as SI has said, use a step cutter, hey make a much cleaner hole. The only time I use a holesaw for fitting sensors is if they are the king with a surround that fits from the outside. If you are going to fit the newer OPS sensors, get the holders that fit inside the bumper. This is the neatest solution as you don't have to have a surround around the sensors. This is the same as the MK6 from the factory. Unfortunately, I had to get the Skoda holders as my holes were already there from factory. I wish it hadn't come with any sensors tbh.
