Author Topic: Which is the fuse for cluster/ highline clocks?  (Read 6974 times)
Offline RoMocop
« on: December 02, 2012, 10:17:53 pm »
Hi, is anybody able to tell me which is the fuse for the instrument cluster /clocks and would it be ok to disconnect this for 5 mins or so?
Cheers.  :happy2:
Re: Which is the fuse for cluster/ highline clocks?
« Reply #1 on: December 02, 2012, 10:24:57 pm »
The actual fuse positions seem to vary with different year cars (thanks VW).
I would just disconnect the battery instead to reboot everything. You'll get a few dashboard warning lights on reconnection but those should extinguish themselves with a short drive.
Offline RoMocop
« Reply #2 on: December 02, 2012, 10:27:17 pm »
Tell me about it, have tried to google it and finding lots of different answers. I have already disconnected and connected the battery a handful of times. :rolleye:
Offline RoMocop
« Reply #3 on: December 02, 2012, 11:03:26 pm »
Finally found it- just for reference it was F17 (5A) in the engine compartment. So much for the handbook which listed F17 being the horn. :confused:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: December 02, 2012, 11:05:36 pm »
why do you want to reboot the cluster?
Cluster and Key coding
Location Great Yarmouth
Offline RoMocop
« Reply #5 on: December 02, 2012, 11:13:10 pm »
I was asked to by Auto polar, having an issue with it since fitting polar fis, top part of my display goes black when on the home menu:
This is mine:
and this is in Mandys:
Not quite sure whats gone wrong.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: December 02, 2012, 11:18:10 pm »
Polar FIS at its worst
« Reply #7 on: December 02, 2012, 11:20:19 pm »
thing they are making the polar fis do to many things--they should of just kept it at the basics
Offline RoMocop
« Reply #8 on: December 02, 2012, 11:20:39 pm »
Do you have any ideas or clues what it could be? It only happens on the home menu, all others are normal. :sad1:
Offline Baz300
« Reply #9 on: December 02, 2012, 11:31:27 pm »
Are you able to change what parameters appear on the screen?
I got my polar and audio menus back but it still freezes when I try to change the peramiters
Swapped back to my old gateway and it has not made a difference
Offline RoMocop
« Reply #10 on: December 02, 2012, 11:35:23 pm »
No I have not been brave enough to try changing the parameters lol. Just want to get my display back first- one step at a time lol.
Offline Baz300
« Reply #11 on: December 02, 2012, 11:38:38 pm »
I pulled the stereo fuse out for 5 mins and that has solved the lost screen issues
The clock comes up on the open door screen for me too.
I'm tempted to try and install an older firmwear.
« Reply #12 on: December 02, 2012, 11:39:56 pm »
i would try the old firmware and try that as you have nothing to lose
« Reply #13 on: December 03, 2012, 11:07:05 am »
fwiw with the latest firmware 3.0 I have no such issues with my silver polar.
I must caution you on trying to downgrade to the earlier 0.2.7 version if you are using a 7NO canbus gateway in light of my own experiences with the two.
Offline Baz300
« Reply #14 on: December 03, 2012, 11:53:41 am »
Polar now think that I have a faulty unit and will be sending me a new one
So I am hoping that will fix the problems
