Author Topic: Fitting Golf 6 MFSW into the Golf 5  (Read 5815 times)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Fitting Golf 6 MFSW into the Golf 5
« Reply #15 on: October 13, 2013, 10:03:09 am »
what wheel did you buy as there are 2 possible looms for a mk6 wheel
Cluster and Key coding
Location Great Yarmouth
Offline valle
« Reply #16 on: October 13, 2013, 10:35:50 am »
Offline vrod
« Reply #17 on: October 23, 2013, 02:43:31 pm »
Hi.
The mk6 < and > buttons communicates through BAP as far as i know. If you code the RNS510 with BAP you will lose NAVI on the MFD but the < and > will work with it. If you use DDP (disabling BAP) they will not work but you will get NAVI on the MFD.
In the meantime i had the mk6 MFA premium cluster installed which works flawlessly with the mk6 mfsw. Can def. recommend it!
