Author Topic: rcd510 dab  (Read 897 times)
Offline ukshaun
  • If in doubt.. flat out
rcd510 dab
« on: December 03, 2012, 12:39:26 pm »
Hi im looking at getting an rcd510 dab, Just wondered if anyone knows if i need to change the aerial? I dont have dab at the moment. Also will this work on normal radio stations if i dont change the aerial?
Im guessing my current ipod dock thats in teh glove box will just plug into the back of the aux on the rcd510. I assume my current cd player is like that anyway.
thanks  :happy2:
My progress thread www.mk5golfgti.co.uk/forum/index.php/topic,66117.0.html
Mods done: revo map, new south boost gauge, rcd510 dab, gti grill, gti colour coded valance, tinted lights, leds, gti spoiler
Offline MikeA
Re: rcd510 dab
« Reply #1 on: December 03, 2012, 06:40:20 pm »
Hi i just added a RCD510 dab to my ED30 i purchased the following
dab Aerial http://www.ebay.co.uk/itm/BLAUPUNKT-KENWOOD-BEAT-ALPINE-Stereos-Glass-Mount-Car-DAB-Radio-Aerial-Antenna-/400354803941?pt=LH_DefaultDomain_3&hash=item5d370180e5  Fits and works well
Antenna adapter http://www.ebay.co.uk/itm/FAST-to-EU-RNS510-MFD3-RADIO-ANTENNA-ADAPTER-FM-VW-Fakra-RCD510-7L6051551-/300818749215?pt=UK_In_Car_Technology&hash=item460a31d71f not needed but made it a breeze to fit
not sure about the ipod connection i had one on my rcd300 but it dosn't work at the moment, not sure if its a cabling fault or i may have to buy a Mdi unit.
hope this help
Current Mk7 2016 5dr GTi Clubsport Edition 40 DSG - No. 403
Tornado Red, Dynamic Chassis Control, Rear View Camera and 19" Brescia Alloys
Previous MK5 2007 3dr Edition 30 Manual - No. 376
Black, Rear parking sensors, Winter pack
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: rcd510 dab
« Reply #2 on: December 03, 2012, 09:54:51 pm »
Okie dokie so, firstly yep the rcd510 will work using the normal radio FM on the left of the unit, but no dab.
As for the antenna adapter you don't actually need one, you can just take the plastic off you old single antenna end and then you have the 2 ends to plug into the back of the new unit  :happy2:
Dab wise you can use a windscreen version which  cost about £20 (dabonwheels) http://www.dabonwheels.co.uk/AFAR_Amplified_internal_glass_mount_DAB_car_aerial_.html
This is what I used to have and works pretty well bit have since upgraded to a new polo short whip dab roof mounted aerial which replaces the standard aerial with an extension cable run to the front of the car. This is more expensive but signal strength is far superior  :smiley:
Your iPod should work as you mentioned but dot quote me lol
