Author Topic: Changing actual number plates  (Read 1981 times)
Offline gigolo456
« on: December 04, 2012, 05:04:18 pm »
Hi Folks, yes i have used the Search function but for the life of me, i can't find anything that details what's involved in changing the front and rear number plates!? Anyone have any links by any chance?  :driver:
Many thanks
Andrew
Offline garrardrj
  • -Given: 76
  • -Receive: 42
Re: Changing actual number plates
« Reply #1 on: December 04, 2012, 05:15:59 pm »
Is that just so you can fill up the tank for free  :grin:
Offline gigolo456
« Reply #2 on: December 04, 2012, 05:18:50 pm »
Sh*t, my secrets out! ;-)
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #3 on: December 04, 2012, 06:19:43 pm »
Many thanks
Andrew
You just unscrew them  :confused:
Offline chrisr763
  • -Receive: 62
« Reply #4 on: December 04, 2012, 06:28:49 pm »
Many thanks
Andrew
I think more detail is needed. Are we talking about stuck on plates? Because 90% of cars are just two screws under covers which just pop up
Offline gigolo456
« Reply #5 on: December 04, 2012, 07:14:12 pm »
Thank u 4 the constructive comments folks! Mine r stock and screwed in so to speak! Am being given a personal plate 4 my impending 40th, lol, so assuming they r just plates, so is it best to just stick new ones on, after removing current ones of course, r have them drilled and screwed in, ie proper dealer job??
Cheers!
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #6 on: December 04, 2012, 07:17:12 pm »
What !
Can you not use a screwdriver  :rolleye:
Offline gigolo456
« Reply #7 on: December 04, 2012, 07:22:19 pm »
I give up, lol, I assume new plates dont come with ready made holes in em, plse correct me if im wrong!?
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #8 on: December 04, 2012, 07:27:30 pm »
Use the old plates as a template drill throught the old ones and through your new ones , go from the front to the back (The white or coloured bit drilled first ) Use a drill bit for wood and use an electric drill , put the drill bit in the electric drill and press the button putting the drill bit where you want to drill the hole and press firmly .
PS . Make sure the plates are not on your lap.
Offline gigolo456
« Reply #9 on: December 04, 2012, 08:29:25 pm »
Oh we have a comedian I see! Trust me, the only DIY I do is after the watershed, lol! Halfords fit them anyway for £6 apparently, jobs a good'n, I hope! ;-)
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #10 on: December 04, 2012, 08:34:30 pm »
this is literally one of the easiest mods you will ever be able to do. dont take it to halfrauds - like GarrardRJ says and just put the old ones on top of the new ones (a little masking tape holding them together helps so they dont move), and drill through.
Seriously i cannot believe there is so many posts on this  :evilgrin:
Offline Frodo-anni
  • -Receive: 45
« Reply #11 on: December 04, 2012, 08:40:04 pm »
Or just buy some self adeshive tabs, stick to back of plate and stick to car, hold firmly for 20-30secs, Job Done  :happy2:
mk5 GTI Edition 30 DSG No0391
Offline gigolo456
« Reply #12 on: December 04, 2012, 08:47:39 pm »
No drill, yes u heard right, lol, and im sure my 7 yr old screws will need changing, and sum of the caps are missing too, and they come as part of the Halfords job! Thanks thou for the suggestions!
Offline gigolo456
« Reply #13 on: December 04, 2012, 08:48:23 pm »
Offline gigolo456
« Reply #14 on: December 04, 2012, 08:49:06 pm »
