Author Topic: Help required from early mk5 Gti owners with highline.  (Read 5705 times)
Re: Help required from early mk5 Gti owners with highline.
« Reply #15 on: December 04, 2012, 10:42:29 pm »
I assume in that ^^video you don't have the polar installed?
Offline RoMocop
« Reply #16 on: December 04, 2012, 10:44:31 pm »
No it is not installed. I was hoping by removing the polar unit it would bring the upper display back but seems like this is not the case. This is why I wanted others to post a video of theirs so I can show auto polar its not normal.
« Last Edit: December 04, 2012, 10:46:46 pm by RoMocop »
« Reply #17 on: December 04, 2012, 11:00:09 pm »
The screen and back light should be ok as when you first get into the car it illuminates correctly...  :confused:
When the upper screen goes black, do you still see the clock on your sat nav if you turn it off?
This assumes your nav is running a firmware that supports the clock showing on its screen when turned off with the key in the ignition.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #18 on: December 04, 2012, 11:03:00 pm »
does that still happen when the polar FIS is removed?
Cluster and Key coding
Location Great Yarmouth
Offline RoMocop
« Reply #19 on: December 04, 2012, 11:03:43 pm »
Do you mean a clock on the RNS, if so I dont have a clock on my RNS.
« Reply #20 on: December 04, 2012, 11:04:30 pm »
Thing that is removed in the vid
Offline RoMocop
« Reply #21 on: December 04, 2012, 11:04:38 pm »
Yes it does. :sad1:
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #22 on: December 05, 2012, 10:37:06 am »
Not the best pic
Andy, was your ignition on when you took that pic?
« Reply #23 on: December 05, 2012, 10:40:46 am »
The ignition was of Mandy when i took the pic
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #24 on: December 05, 2012, 11:23:11 am »
Do you have a pic of the display when the ignition is on? :smiley:
« Reply #25 on: December 05, 2012, 11:24:18 am »
Give me 2 ticks and i will go and get one
« Reply #26 on: December 05, 2012, 11:44:59 am »
Here you go  :happy2:
Offline Mk5 GTian
  • -Receive: 37
« Reply #27 on: December 05, 2012, 01:24:21 pm »
Mine is exactly the same as Maxitrol's when the driver door is open, either with ignition key in and engine running, ignition key in but engine not running, or ignition key out.
Mine is a October 2005 on a 55 plate.
« Reply #28 on: December 05, 2012, 02:19:32 pm »
Yes it does. :sad1:
Did you put your old Gateway back in?
Offline RoMocop
« Reply #29 on: December 05, 2012, 02:21:18 pm »
Thanks for your input Ian- I dont suppose you could take a short video when you are next out in your car. It would be much appreciated as I want to show auto polar how it should look rather than them telling me mines normal.
I just need as many videos or pics as poss to back me up.
Thank you all for your input so far. :notworthy:
