Author Topic: Cam follower - you're all perverts!  (Read 28810 times)
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Cam follower - you're all perverts!
« Reply #15 on: December 05, 2012, 06:30:42 pm »
not everyone on a car forum knows what they're talking about (except me of course)
Pure gold! :signLOL: :notworthy:
Do you mind if I put that quote under my sig?
'07 Red manual
« Reply #16 on: December 05, 2012, 06:40:07 pm »
....Be my guest (with or without attributing it to myself, RedRobin).
But I suggest you reduce the size of your dildo-men sig before the Mods remove it for being oversize. TC posted a thread about sig image sizes and their size restrictions.  :happy2:
Offline Scrubadub
  • Soon to be "bagged"
« Reply #17 on: December 05, 2012, 06:47:24 pm »
Will a worn follower make any noise?
Fun bags
Offline Aas
« Reply #18 on: December 05, 2012, 06:47:27 pm »
This pic has just been posted by richwig:
^ Cam follower porn for perverts?
Mine was 'Safe' and didn't need changing after 100,000 miles but JKM advised we may as well change it anyway while my APR HPFP was being installed. Apparently with an APR pump the cam follower might need checking more often.
Whereas it's true that not everyone on a car forum knows what they're talking about (except me of course), it's also true that some VW dealer staff don't have a clue. If he has only seen one instance of a failure you have to ask how many tuned cars has he serviced? And especially with an aftermarket pump.
When I changed mine in the summer it looked exactly like no.3 :surprised:! That was 100k and full vwsh, drives fine now but does go into limp mode every once in a while if you really go for it in a high gear. But is fine in lower gears.  I didn't feel any wear on the cam when I changed the follower though.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #19 on: December 05, 2012, 07:03:39 pm »
There has been a few failures on here so i don't believe it's nothing be bother with  :surprised:
It's mainly the yanks that have them fail, which is generally because they have poor oil and the petrol is only something like 93RON so the pump is working hard all the time to make decent power  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #20 on: December 05, 2012, 07:31:18 pm »
Stage 3 only happens if you have an early A camshaft.   Only goes domed shaped if the cam is f*cked.  So I would say your cam is fooked and the follower will already be dead again.  You need a B cam and a new follower.  Get it checked asap.  Is your gti an early one?
Follow AKS tuning on Facebook
Offline JMP
« Reply #21 on: December 05, 2012, 07:52:24 pm »
I changed mine at 99tkm's. It was barely worn, stage 1 from the pictures.. I changed the pump also and there must have been something cooking there, because the engine is now a lot more quite.
Offline GTI5
« Reply #22 on: December 05, 2012, 07:57:38 pm »
Mine at 50k, changed a while ago after remap (Owner from 36k onwards):
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline theo
« Reply #23 on: December 05, 2012, 08:01:56 pm »
I've just changed mine after doing 25k of Stage 2+ running and it looked a little less worn than that. Thought it best as a preventative measure! Better safe than sorry for the cost!
Offline martziniuk
« Reply #24 on: December 05, 2012, 08:24:40 pm »
Just changed my follower. I've had the APR pump on for the last 19k but there's still lots of life left in the follower.
Offline zerolag
  • Ass of Ennis
« Reply #25 on: December 05, 2012, 08:29:21 pm »
What's the part and fitting cost for this at a dealer and decent indy respectively?
I worry about de-pressuring the fuel system enough and doing this myself...
Offline gazbutS3
« Reply #26 on: December 05, 2012, 08:48:02 pm »
Probably half an hour at an Indy, main dealer will tell you it doesn't need changing  :smiley: where you based?
Offline vRSAlex
  • -Receive: 253
« Reply #27 on: December 05, 2012, 08:59:33 pm »
What gaz says.  I charge 30 mins plus the follower is around 28 quid iirc.
Offline Baz300
« Reply #28 on: December 05, 2012, 10:30:02 pm »
I would ask the mechanic for a letter stating that there are no cam follower issues and if it does fail then he will fix the engine for free seeing that they refused to change it for you.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #29 on: December 05, 2012, 10:47:45 pm »
^^^ They didn't refuse to change it...it was a 'there's no point' response. I didn't insist and if I had I'm sure they would do it. In fact I'm booked in for a diagnostic check on Friday so I'll ask for a quote to have it replaced. I might mention some of the comments from this thread...!
'07 Red manual
