Author Topic: Would you buy or not?  (Read 8045 times)
Offline GTI-Ross
  • Learning All The Time :)
Re: Would you buy or not?
« Reply #15 on: December 06, 2012, 11:00:51 am »
Thanks MC, what price roughly am i looking at buying a new or used BT module up for?  is the RNS also compatible with a current Parrot BT kit i have do you know?  Thanks
I had a Parrot Kit in my car (with my RCD510) before I had the OEM BT fitted and worked fine and will with the RNS. 5KO Bluetooth kits are usually available from Eddie-NL on here for around £170 IIRC. A recent For Sale thread......
.http://www.mk5golfgti.co.uk/forum/index.php/topic,51013.0.html
Mmmmm....still no better off in my choice. Keep it OEM (total cost £650 with BT & min) or after market total cost £500 with out sat Nav - (both expensive, when i have other mods in mind)
HELP !!!!   :signLOL:
Offline Squeeguk
« Reply #16 on: December 06, 2012, 11:15:01 am »
Go for a cheaper double din unit then. Stick with the 530BT, will be a lot closer to your £400 budget, or you could go even cheaper and pay around £300. All depends on what you looking to get out of the HU.
Offline GTI-Ross
« Reply #17 on: December 06, 2012, 12:00:37 pm »
just a half decent touch screen that can play music from iPhone and has a decent power output. But even if i buy the 530BT, wont i have to buy the the extra bits as well which will take it over £400.
Offline Squeeguk
« Reply #18 on: December 06, 2012, 12:36:03 pm »
You should be able to do the whole lot for under £400. If you like I can sort you a price for everything you need? Just remember the 530BT does not have the visual display out to display on the MFD, but it does have BT and does do iPod, etc.
Offline GTI-Ross
« Reply #19 on: December 06, 2012, 02:02:02 pm »
I dont think i need it on the MFD, never had it on any other car, so cant see my self needing it now.
Yeah if you can quote for Everything i would possibly need to get this set up, as at the moment i have the standard one in.
Offline Squeeguk
« Reply #20 on: December 06, 2012, 03:49:44 pm »
Will pm you a price. Have to pop out again now, but will do it as soon as I get back in an hour or so.
