Author Topic: Where to run wires through bulkhead to battery???  (Read 6211 times)
Offline Scrubadub
  • Soon to be "bagged"
« on: December 07, 2012, 10:08:32 am »
Trying to find the best route for the wiring for my Air ride but can seem to fund a sensible grommet to feed the wires through?
Just need to get 2 wires to the battery terminals
Any suggestions?
Pics would be great
Fun bags
Re: Where to run wires through bulkhead to battery???
« Reply #1 on: December 07, 2012, 10:23:02 am »
take the battery out and thier is some gromets behind there
Offline Squeeguk
« Reply #2 on: December 07, 2012, 12:23:30 pm »
Yep, as above, right behind the battery is where there is a grommet with the main harness going into the interior.
Offline Scrubadub
« Reply #3 on: December 07, 2012, 02:24:35 pm »
can i do it without disconnecting battery? dont want to lose revo settings :(
Fun bags
Offline Jaywoo-GTI
  • -Given: 38
« Reply #4 on: December 07, 2012, 03:07:22 pm »
I rooted my pipe for my boost guage through that grommit, can be done without removing the battery but is a PITA, just make sure you have plenty of light.
Offline gazon69
« Reply #5 on: December 07, 2012, 03:46:39 pm »
it'll be a nightmare without taking the battery out pal. I wired my meth kit through there.
Offline Scrubadub
« Reply #6 on: December 07, 2012, 04:48:26 pm »
Thats my weekend planned then  :confused: thanks guys
Fun bags
Offline chrisr763
  • -Receive: 62
« Reply #7 on: December 07, 2012, 10:30:58 pm »
Good luck! Shame to loose the settings :( although your getting it done soon are you not? Or just got it done?
Offline Scrubadub
« Reply #8 on: December 08, 2012, 11:45:49 am »
Had it done Wednesday
Fun bags
Offline Polo6n1600i
« Reply #9 on: December 08, 2012, 01:53:04 pm »
I'll get pics and show you were in 5 minutes - it's easy
Offline Scrubadub
« Reply #10 on: December 08, 2012, 04:49:20 pm »
Excellent sounds promising
Fun bags
Offline Squeeguk
« Reply #11 on: December 08, 2012, 09:52:01 pm »
Here you go some pics for you.
Where the battery normally goes:
The bunch of wires going into the firewall:
and the grommet that you need to feed the cable through:
Hope this helps? You really can't miss it.
Offline Polo6n1600i
« Reply #12 on: December 09, 2012, 03:08:28 pm »
I couldn't get back into the p/s footwell. However it is easy to get to.
Remove the tray under the glovebox, once that's out the way you can look right upto the left corner high. Use a wire coat hanger and push it through from the inside, the wire comes out just below the battery. Easy - took 5 minutes to do
Offline andygo
« Reply #13 on: December 09, 2012, 05:54:45 pm »
Just run some long lengths of wire from the battery terminals to the normal wiring. There's hardly any current being used with everything switched off so thin wire should be ok. by doing that, your car is always connected to the batttery, it's temporarily just by a thinner wire.
Offline Polo6n1600i
« Reply #14 on: December 09, 2012, 09:30:14 pm »
Whereas I would say use a thick a wire as you can (I used 4 gauge)
