Author Topic: Hesitation when accelerating  (Read 2989 times)
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« on: December 07, 2012, 11:13:32 am »
As the title says, i've noticed my car hesitates when i first put my foot down around 2k to 3kish revs ive only noticed it when cruising on motorways, its like there's a slight pause before the power comes in and then everything is fine.
I can't get it to do on command it just catches me out unexpectedly and it only seems to do it now and again. I've not long had the sparkplugs and oil changed.
Could this possibly be the DV as I plan on replacing it with a revision G soon.
« Last Edit: December 07, 2012, 11:48:40 am by TomGTI »
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Hesitation when accelerating
« Reply #1 on: December 07, 2012, 11:49:49 am »
Cuuld be a dirty MAF sensor?
You can buy electrical cleaner from halfords which will help to clean it up a bit. maybe worth a try. . .  :smiley:
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #2 on: December 07, 2012, 12:17:46 pm »
Now you say that, the day I got my car the exhaust emission light came on i had it scan and it also showed two faults for the MAF sensor, we didn't know how long they'd been on there and i thought the car was fine so we left it at that, could this be because it was dirty?
I've found the electronic cleaner in halfords online, if I remove the sensor and spray it should this solve the problem, that's if it's dirty and not broken?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: December 07, 2012, 12:57:34 pm »
Its worth a try for the sake of £4 I recon.
Its dead easy to do, just remove 2 screws and pull it out, cover it in electrical cleaner and give it 30mins to dry then stick it back in  :happy2:
Offline GTI-Ross
  • Learning All The Time :)
« Reply #4 on: December 07, 2012, 02:07:29 pm »
Not just some turbo lag?
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #5 on: December 07, 2012, 02:26:04 pm »
No definitely not, theres a slight pause some times before the power comes in not all the time just now and again. I'll give it a good clean tomorrow if its dry and hopefully it should solve it.
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #6 on: December 10, 2012, 09:55:52 am »
Cleaned my MAF sensor over the weekend and still not change, I will be getting a revision G DV soon are they hard to fit?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7 on: December 10, 2012, 09:59:12 am »
Ko3 or Ko4?
Edit: just seen your sig. Ko3 is actually on the turbo unit, passenger wheel off and whip out the arch liner is the best approach iirc  :happy2:
« Last Edit: December 10, 2012, 10:03:13 am by fab5freddy »
Offline mk5craig
« Reply #8 on: December 10, 2012, 10:09:26 am »
 I also have this problem, mine normally happens when I start the car up in the morning, once it does it it won't do it again til the next morning,
Posted on here a while back but no one really knew, a few suggestions was the cat,so will be good to hear people suggestions
What mileage are you on?
Craig
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #9 on: December 10, 2012, 03:04:04 pm »
Just over 50k miles it doesn't do it on start up just when I'm cruising along.
I'll look in to fitting the DV then along as its not too much of a pain to fit.
