Author Topic: R32 Highline Clocks Fitted. Some menu options missing.....  (Read 1361 times)
Offline trs888
  • -Given: 17
  • -Receive: 20
« on: December 07, 2012, 08:10:05 pm »
i just got my R32 Highline Clocks back from Kalu today and fitted them.
looking awesome, but going through the menus at first the LIGHTS AND VISION was not enabled. this soon displayed after a little drive around. looking on this page http://www.myturbodiesel.com/1000q/a5/multifunction-display-VW.htm
the Convenience menu is not available on my car. also the MENU button on the MFSW does nothing
Can i get that menu? do i have to change anything? how come the button is not working?
i have a 2005 GTI with 2007/8 MFSW Buttons and ive changed the Can Gateway (if that makes any difference i dont know) for use with my RNS510
Does the mirror down on reverse option only appear with the folding mirrors as mine are just electric, not folding. is that something to do with the window motor units?
i also want to change the door locking after move off. (to lock the doors)
any help would be appreciated!
Thom
« Last Edit: December 07, 2012, 08:11:49 pm by trs888 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: R32 Highline Clocks Fitted. Some menu options missing.....
« Reply #1 on: December 07, 2012, 10:23:43 pm »
The menu button is dependent on SW that is installed on the cluster
lights and vision
convenience
are only available with highline versions of CCM & CECM
Cluster and Key coding
Location Great Yarmouth
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #2 on: December 07, 2012, 11:03:24 pm »
lights and vision
convenience
thanks for that info. so my next question is - how, where and what (part no) do i get to use those options, or is it programmable with vagcom anyway? if i have lights and vision, does that mean i have high line CCM but not CECM?
Offline SI-R32
  • -Receive: 125
« Reply #3 on: December 08, 2012, 05:39:58 pm »
lights and vision is cecm so if you have this bonus
convenience is ccm this unit is tucked away behind the glove box and is quite an easy change, you will need some one with vag com though
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #4 on: December 08, 2012, 06:06:00 pm »
I need to update both of mine to get the better options  :sad1:
