Author Topic: Fitting polar fis  (Read 823 times)
Offline craig_t
  • Craig
Fitting polar fis
« on: December 08, 2012, 05:15:38 pm »
Just brought a polar fis from a guy on here, just wanted to gauge how hard it is to fit. I recently fitted a new gateway as I was having battery drain issues with my rcd510.
This was a painful job I remember, my gateway is up under the clutch pedal and there isn't much room to get your hand up there. But am I right in thinking fitting the polar is going to be easier?
Admin notice, sig pic removed for being to big.
Re: Fitting polar fis
« Reply #1 on: December 08, 2012, 07:18:55 pm »
If you can manage to unplug the plug into the gateway without removing the actual gateway (very difficult to do IMO) then all will be easy to install.
Did you remove the plastic piece at the bottom of the dashboard when you last did the gateway replacement as you get more room for maneuvring if you did.
« Reply #2 on: December 08, 2012, 08:05:46 pm »
i did mine all in situ and only removed the heater ducting --just need strong finger to unplug the red connectors :happy2:
