Author Topic: Clutch DMF options  (Read 906 times)
Offline Rustybear
  • -Given: 243
Clutch DMF options
« on: December 08, 2012, 06:14:46 pm »
Been told that as I have the clicking sound when clutch pedal not pressed the DMF is on its way out which won't be part of a new clutch which also needs replacing. First, do I need to replace clucth and DMF as different parts? If yes, what are options of replacing with normal cheaper flywheel? Sorry not mechanically minded  :confused:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Clutch DMF options
« Reply #1 on: December 08, 2012, 07:14:13 pm »
Is your clutch worn out? Does it slip? If not then it doesn't need replacing. Although it will have to be removed to replace the flywheel so (for about £150) you could replace it.
eurocarparts.co.uk sell OEM LUK flywheels for around the £300 mark.  :happy2:
Offline Rustybear
  • -Given: 243
« Reply #2 on: December 08, 2012, 07:21:38 pm »
Clutch ain't slipping just biting high so as you say might as well replace when doing DMF I suppose.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #3 on: December 08, 2012, 08:11:49 pm »
Definately.
Get it all done at once... LUK DMF's are about cheaper i think, can't remember what i paid for mine as it was through APS Brackley who are Sachs Authorised dealers, and fit the 400ftlbs Sachs uprated clutch.
Diesel Daily Hack.
