Author Topic: Best drop for car with Monza 17's?  (Read 2649 times)
Offline ianv5
« on: December 09, 2012, 12:31:42 pm »
Looking at some springs for my GTI and just wondered what is the best drop e.g 30mm/45mm etc  but I am keeping my 17inch Monzas
, without to much comprise in ride comfort etc. Eibach/H&R??
Any pictures would be good with Golf lowered on 17's
Offline Lone_Par
Re: Best drop for car with Monza 17's?
« Reply #1 on: December 09, 2012, 12:38:32 pm »
There are a couple of pics in my members ride thread with mine lowered on eibach sportlines. Links in my sig.
Offline ianv5
« Reply #2 on: December 09, 2012, 01:01:48 pm »
Thanks mate, will check itout :happy2:
Offline ianv5
« Reply #3 on: December 09, 2012, 01:08:38 pm »
So where did you get the sportlines from and what is the ride like?
Also what drop did you get looks about right in the picture?
« Last Edit: December 09, 2012, 01:14:58 pm by ianv5 »
Offline Lone_Par
« Reply #4 on: December 09, 2012, 01:54:15 pm »
Got them from Demon Tweeks I think. Sure the drop was about 45-50mm.
Offline Lone_Par
« Reply #5 on: December 09, 2012, 01:54:49 pm »
Ride is fine - almost as if your running standard. Bit firmer but solid in the bends.
Offline ianv5
« Reply #6 on: December 09, 2012, 01:55:52 pm »
Thanks mate, that is quite a low drop :happy2:
Offline Lone_Par
« Reply #7 on: December 09, 2012, 02:15:36 pm »
Maybe wasn't as much as that to be honest, but not far off it.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #8 on: December 09, 2012, 02:55:48 pm »
It's a 45mm drop for a standard golf or a GT. the GTI sits lower than the others so these will springs will only give YOUR CAR about 30mm MAX.
Mine is on H&R's and sits slightly lower than Eibachs, ride comfort is great, just slightly firmer than stock. No scraping over speed bumps even with 5 adults in.
There's plenty of threads on ride comfort with lowering springs but they all give the same answer.
Gray
Offline ianv5
« Reply #9 on: December 09, 2012, 02:58:52 pm »
What H&R do you have, drop?
Gray
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #10 on: December 09, 2012, 03:06:07 pm »
Gray
I think there is only one spring type that H&R do. I bought mine from Larkspeed as they were the cheapest. You get an ACTUAL 30ish mm
Offline ianv5
« Reply #11 on: December 09, 2012, 03:09:54 pm »
Gray
I just had a look and yes they only have 30mm drop. Will give them  a go as had had eibachs on my golf v5 and have heard good things on here about H&R's. Thank you.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #12 on: December 09, 2012, 03:49:37 pm »
You want o keep stock dampers?
- Volkswagen OE ('Driver Gear' / 'Volkswagen Zubehör')
- Eibach Pro
NO OTHERS, PERIOD.
"You get what you pay for."
Offline Lone_Par
« Reply #13 on: December 09, 2012, 06:28:39 pm »
Gray
Ok. Thanks for SHARING that INFO about MY CAR. ;-)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #14 on: December 09, 2012, 06:34:16 pm »
Gray
 :grin: presuming yours is a GTI, you only get 30mm (ish) from eibachs. If yours was an SE or summat, then 45mm is achievable  :happy2:
Bit of emphasising going on here  :drinking:
