Author Topic: B Pillar Airbag removal  (Read 4359 times)
WILLZIE
« on: June 29, 2009, 11:38:47 am »
Anyone know how to remove this?, As I am replacing the rear passenger interior panel on my 3 door and it would make it a whole lot easier with this off! as theres no way I want to damage the new panel!. Ive undone the clips but its the top were it doesn't want to budge, though I don't wana set the damm thing off.
Ta!
« Last Edit: June 29, 2009, 11:40:54 am by WILLZIE »
Offline mortygttdi
  • -Receive: 146
Re: B Pillar Airbag removal
« Reply #1 on: June 29, 2009, 12:39:41 pm »
You would be hard pushed to set it off mate the ignitor is in the back under where the roof antenne is. You would also need to strip the full head lining and pillar trims off before you could take the roof airbags out, its not just a single one for the B-pillar it goes from the bottom of the A-pillar right back to the rear of the roof lining the full airbag is about 3 1/2 ft long.
The B-pillar has a screw under the airbag badge at the top and is just a flap at the bottom so once youve under the screw and seperated the top the bottom should just lift upwards.
Darren
