Author Topic: rs4 fuel pressure valve  (Read 5795 times)
Offline chopper
« on: December 13, 2012, 07:09:54 pm »
Was debating getting a rs4 fuel pressure valve for my REVO 2+ edition 30..... APR HPFP, OEM REV DV and PCV,  APR RSC TBE, Forge twintake and twintercooler....
Has anyone else got one for the same/similar setup and found it made a difference?
Re: rs4 fuel pressure valve
« Reply #1 on: December 13, 2012, 08:19:22 pm »
May or may not make a difference depending on if your present value is totally in spec with a cracking pressure of exactly 130bar.
Offline AndrewJB
  • die gelbe Baron
« Reply #2 on: December 20, 2012, 05:36:24 pm »
As said it will only make a difference if you car is requesting the amount of pressure that the OEM one cant take
Im fitting one to my 2.0TFSI just for the sake of it, even though APR said i dont need it
« Reply #3 on: December 20, 2012, 11:02:07 pm »
I think APR supply it with their K04 kit (definitely the stage 3 kit), so for the cost of one it is a no brainer. Bit fiddly to fit though.
Offline AndrewJB
  • die gelbe Baron
« Reply #4 on: December 21, 2012, 07:14:46 am »
Hence why im paying Alex to do it  :laugh:
Offline dokez
« Reply #5 on: December 29, 2012, 08:00:16 pm »
fiddly but its simple to fit. I didnt notice no difference so took it off and sold it. stage2+ for me.
« Reply #6 on: December 29, 2012, 08:35:29 pm »
What difference were you expecting??
Offline dokez
« Reply #7 on: December 29, 2012, 08:45:09 pm »
remove the flat spot up higher revs that occur when stage2+
Offline bobsey
« Reply #8 on: December 30, 2012, 06:25:34 pm »
Dont you mean flat spot that shouldn't occur when running on stage 2+, is it revo by any chance?
Offline dokez
« Reply #9 on: December 30, 2012, 08:59:05 pm »
correct. However reading from here its normal and the rs4 sorts it out but not for me.
« Reply #10 on: December 30, 2012, 10:28:45 pm »
Did you log your actual vs requested fuel rail pressure?
Offline bobsey
« Reply #11 on: January 01, 2013, 08:21:07 pm »
Its not normal there is always something to blame for it happing, which i still havent got to the bottom of on mine.
The rs4 return valve did not help mine either.
Offline 56OctyVRS
  • -Receive: 72
« Reply #12 on: May 16, 2013, 11:29:14 am »
It  cured my flat spot. Even if it didnt I would leave it on as the oe ones can fail as they get older. At least you would know the fprv is new and working fine.
