Author Topic: Ed 30 Buying Advice  (Read 984 times)
Offline thegolfather
Ed 30 Buying Advice
« on: December 14, 2012, 01:12:15 pm »
Viewing tomorrow and would appreciate some advice on what I should check over and above usual, questions to ask dealer, key service milestones/schedule etc
Thanks in advance.
Offline Poppa Dom
Re: Ed 30 Buying Advice
« Reply #1 on: December 14, 2012, 06:40:39 pm »
OK - For starters, all the usual things as you mention.
DSG Car - Take out for drive, check gearbox, is it jerky at all on take up or smooth? DSG oil should be changed every 40k. Other points - paint bubbling on arches, check boot, lift up carpet check for damp, usual pad/disc wear. Check 2Zone climate control. Make sure AC compressor is working - with engine running put onto low and check that ice cold air starts circulating after a min. If not it may need regassing/issue with AC pump (this is quite a common point of failure it seems).
Cambelt - Interval is 60k / 4 years which ever is sooner. Clarify as to whether the water pump was changed with the cambelt if it has had a change.
Not a huge amount of specific points to check above and beyond the normal points really.
Offline Black9
  • -Given: 35
« Reply #2 on: December 14, 2012, 07:07:46 pm »
As above & also have a listen for knocking from front suspension. Both my MK5s had it. Cheap to fix, hard to find the cause usually and labour ain't cheap
Buy and eddy and remap it. U will never look back
Offline wagonboy
  • Nov.2007 ED30 dsg reflex silver
« Reply #3 on: December 15, 2012, 09:48:28 am »
As all said above, if its a good one you'll love it. Had mine over 4 years and it still gives me great pleasure to drive. If you get it........ ENJOY.
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #4 on: December 15, 2012, 10:17:20 am »
Make your mind up whether you want to buy it before you go an drive it as you will definitely want it after driving it .  :happy2:
Get the same buzz every time i drive mine as i did when on the test drive - Did 160 miles in mine yesterday , the first i have driven it since 9th November and it was fantastic , 112 more miles to get it to 20k ! Wish i had more journeys to do in it as its wasted on me being driven so little.
« Reply #5 on: December 17, 2012, 12:28:01 pm »
Thanks guys. Didn't see it over weekend. Will be this week now.
Offline golfather
« Reply #6 on: December 17, 2012, 01:29:49 pm »
