Author Topic: RNS 510 SD card slot issues.  (Read 1018 times)
Offline ell.s
« on: December 15, 2012, 04:15:40 pm »
Hi all
Been trying to get my sd card to work in my car today I've got an RNS 510, and when i just click in the SD card the unit doesn't see its there but if I push it right in and keep pressure on it, it works fine but as soon as i take my finger off it no longer sees the card. is this a common problem and is there any chance there is an easy remedy?
Re: RNS 510 SD card slot issues.
« Reply #1 on: December 15, 2012, 08:27:08 pm »
Have you tried another sd card?
Offline ell.s
« Reply #2 on: December 16, 2012, 12:34:22 am »
I have only got 1 to hand but ill try and dig another out tomorrow.
Offline SI-R32
  • -Receive: 125
Re: Re: RNS 510 SD card slot issues.
« Reply #3 on: December 16, 2012, 10:10:49 am »
Does it click when you put it in the click when you take out like putting it in a PC, does it have a bit of spring tension on it, I've seen these play about usually push in out many times till the mechanism holds it in
Offline ell.s
« Reply #4 on: December 17, 2012, 12:08:45 am »
Yeah it doe click I must have had it in and out 100 times over the past 2 days and tried another card today and its still the same :(
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: December 17, 2012, 12:25:09 am »
take the unit out and see if the ribbon cable is connected properly
i can get spare parts for the rns
Cluster and Key coding
Location Great Yarmouth
