Author Topic: Best Pressure Washer For Your Car  (Read 4035 times)
Re: Best Pressure Washer For Your Car
« Reply #15 on: December 18, 2012, 07:58:57 am »
If you are buying from eBay there are loads to choose from. Trouble is all the good prices are often refurb washers with a very short warranty. 1-3 mths.
However, I managed to find one that came with a 1yr warranty and the guy that dealt with these refurbs lived only 10miles away. I met him, and he was a real nice bloke. He sold me a unit that had been returned because a lady had cross threaded the valve that the hose attaches to. It had never been used, it was still brand new.
He simply replaced the valve and I bought a 3.15 for £80 with 1yr warranty.  :happy2:
One bit of advice is try to keep said valve well lubed. It's so easy to cross thread the plastic threads on the machine when attaching the hose.  :wink:
Offline john87
  • -Receive: 53
« Reply #16 on: December 18, 2012, 10:00:59 am »
I had a karcher 3.99m, great washer with excellent pressure...however it suffered frost damage and I replaced it with a Nilfisk C120.something, which is just as good if not better. ok, I miss the vario lance, but the nilfisk has a better flow rate (better snow foam results) and has a metal screw fitting for the HP hose  :happy2:
Offline ripmateyy
« Reply #17 on: December 25, 2012, 09:58:13 pm »
Nilfisk C125 (125bar) with loads of attachments is only £99.99 at Argos!
