Author Topic: ABS rear sensor rings  (Read 8775 times)
Offline brough74
« on: December 16, 2012, 04:06:02 pm »
Has anybody changed the rear abs sensor rings ?
Can they just be changed by themselves ?
Just im still having trouble with my abs and have put 2 brand new rear speed sensors in today to no avail and now im starting to get angry with it.
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
Re: ABS rear sensor rings
« Reply #1 on: December 16, 2012, 07:49:35 pm »
Any vcds fault code?
Offline brough74
« Reply #2 on: December 16, 2012, 08:36:47 pm »
FAULT CODE 00290 ABS WHEEL SPEED SENSOR, REAR LEFT G46.
003 - MECHANICAL FAILURE - INTERMITTENT
00287 ABS WHEEL SPEED SENSOR, REAR RIGHT G44
Now after fitting new sensors today and trying to clean the rings it says it cant read it either - implossiable signal.
Never rains but it pours lol
« Last Edit: December 16, 2012, 08:43:03 pm by brough74 »
Offline smil3r
« Reply #3 on: December 17, 2012, 05:48:56 pm »
I fixed one the other day that had the exact same symptoms as yours. Changed the sensor but to no avail. Changed the bearing (abs ring attached to it) took it for a short drive and the light went out. Cleared the codes with VCDS, checked a couple of days later and it hadn't came back.
Bearing is easy enough to change, take off the brake disc carrier, remove the brake disc, remove the grease cap and undo the nut. The bearing should then just slide off.
Offline brough74
« Reply #4 on: December 17, 2012, 07:19:44 pm »
Cheers SMIL3R looks like i will need to get some bearings ordered tomorrow, hope i get the right size ones
Offline brough74
« Reply #5 on: December 28, 2012, 05:22:09 pm »
Finally got my bearings fitted, and after £142 for 2 new sensors, £100 for 2 new bearings, £90 for a scan at VW, £25 for spline bits and then a bent pin on a sensor all is working now. The sensor rings were well and truly damaged and rusted away.
