Author Topic: Replacing accelerator pedal.  (Read 6369 times)
Offline Matto
  • -Receive: 116
« on: December 16, 2012, 04:54:47 pm »
I have just got hold of some R32 pedals and wanting to know is it a matter of unplugging the old and plugging in the new one? Or is there some adaptation to be done? Did have a quick search on here and came across a thread which described throttle/throttle body adaptation.
Re: Replacing accelerator pedal.
« Reply #1 on: December 16, 2012, 04:58:21 pm »
Yup, you'll need vcds for adaption post install...
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: December 16, 2012, 05:44:33 pm »
Are the tdi acc pedals not different to the petrol pedals?
Do you have the tool to remove the old pedal Matt?
Follow AKS tuning on Facebook
Offline Matto
  • -Receive: 116
« Reply #3 on: December 16, 2012, 05:50:04 pm »
I've got VCDS so that's no problem.
Alex, I just assumed they would be the same. What tool is needed? Something special?
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: December 16, 2012, 06:16:58 pm »
It's a twin pronged tool that slides into the bottom of the pedal to release the clips.  I have one.
I know the one in my altea is different, but yours may be the same.
Offline Matto
  • -Receive: 116
« Reply #5 on: December 16, 2012, 06:28:12 pm »
Ah right ok. Will look at the R pedal and see if I can see how that was fastened down. How did you think the petrol one was different to the diesel one?
Do you know anything about the adaptation procedure?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: December 16, 2012, 06:35:06 pm »
I changed mine twice, and didn't do the adaption
Petrol ones work fine on a Diesel
Cluster and Key coding
Location Great Yarmouth
Offline Daffy
« Reply #7 on: December 16, 2012, 06:43:57 pm »
Same here. Have not noticed any problems.
Offline DFish
« Reply #8 on: December 16, 2012, 07:03:50 pm »
Special tool... haha I just used two screwdrivers.
Fish
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Replacing accelerator pedal.
« Reply #9 on: December 16, 2012, 08:22:20 pm »
I've fitted r32 pedals to my tdi, no problems.  Think I used a screw driver to remove the old one.
It wasn't difficult anyway.
Jas
VCDS (Preston, Lancashire)
« Reply #10 on: December 16, 2012, 08:42:24 pm »
Offline Matto
  • -Receive: 116
« Reply #11 on: December 16, 2012, 10:19:23 pm »
Cheers bacillus. That was what I read the other day. Someone had copy and pasted it into a thread on here. It does seem after a quick read I won't need or be able to do it and I have learnt something. It says TDi's don't have a throttle body.
Offline Matto
  • -Receive: 116
« Reply #12 on: December 18, 2012, 05:16:04 pm »
Little update and just for info really. I managed to fit the R pedals with no problems. After seeing how they came out I managed to remove mine with a couple of screwdrivers. I also found that the plastics had been broken on the R pedal by whoever removed them. I decided to remove just the R pedal part and fit to my actuator part. Nice and easy to do and means I keep my original pedal.
I also checked the part numbers for the different pedals and they are the same bar the last 2 digits. For example the original was 6PV 008 745 - 00 and the R was 6PV 008 745 - 20.
« Last Edit: December 18, 2012, 05:22:20 pm by Matto »
Offline marko
« Reply #13 on: December 18, 2012, 10:53:47 pm »
striaght swap on a tdi with no need for vcds...
