Author Topic: Router advice BT  (Read 664 times)
Offline Baz300
Router advice BT
« on: December 16, 2012, 04:59:49 pm »
I have a BT homehub 2 on an ADSL connection
The router has been disconnecting itself and losing wifi signal several times a day over the last few weeks.
I have asked BT for a replacement but the only thing they have done is offer to sell me a homehub 3.
What's the best router out there at the moment? As I'm not willing to pay BT for a new router
Offline Lone_Par
Re: Router advice BT
« Reply #1 on: December 16, 2012, 05:03:51 pm »
I got a Netgear DGN3300 mate. Set me back about £115 or something, I upgraded from a home hub 2 and its been like night and day.
« Reply #2 on: December 16, 2012, 07:47:59 pm »
Have you checked to see how many other local networks are using the same wireless channel as you?
Offline richtung
  • -Receive: 56
« Reply #3 on: December 16, 2012, 07:53:01 pm »
was about to advise this also  :happy2: You would be suprised how many othe wireless networks will be in your vacinity and chances are, they are causing really bad interference.
Rich
« Reply #4 on: December 16, 2012, 08:08:07 pm »
There's a programme out there called InSSIDer which will tell you all the networks out there.
Offline zerolag
  • Ass of Ennis
« Reply #5 on: December 16, 2012, 08:23:18 pm »
Best router?
Well, I bought a ASUS RT-AC66U a few weeks ago, and now I've sorted my modem out, it's FOOKIN rocks, the range is silly good.  It's expensive but quality.
I have it in my garage and my mate 5 doors down can see it on his WIFI search, pmsl!
To OP: I'd check the simple things first...
1. Phone line... your master box into the house, all good? no loose connections, does main phone line work without crackling?
2. Modem/Router position... whack it straight onto your main incomer and test BB connection
3. Filters... get a new filter for your main line, these are notorouis for failing/drying out
4. All above good; do a ping test: http://pingtest.net/ and compare
5. Employ a pro to sort you out in 30 mins :)
Offline Baz300
« Reply #6 on: December 16, 2012, 08:53:58 pm »
I have ran inssder and changed the channel but some channels do now work with my iPhone or iPad.
Half the time it is the router losing wifi signal and a reset fixes it, then it's the box losing connection to the broadband.
Resetting the router works every time that there is a problem
All the filters in the house have been replaced two weeks ago, and there is no issues with crackling on the phone lines.
I had the same problems with the first bt homehub and the homehub 2 fixed everything but I am getting all the same problems 2 years later
