Author Topic: Are these hard to fit? multi-func steering wheel; highline cluster; satnav?  (Read 1194 times)
Offline Squirrelofdoom
Hi guys,
I'm still looking for a MK5 gti or Ed30 to buy. I've found a nice ed30, but it doesn't have a few of the things I wanted with the car. These are the multifunction steering wheel, highline meter cluster and satnav.
Eventually I wanted my car to have the RNS-E 510 satnav unit, linked to a highline meter cluster (so that it shows the navigation directions on the meter cluster) and the multifunction steering wheel. How difficult is it to retro fit these? Is it more difficult to add the RNS-E to a car which DIDN'T come with the satnav option?
Thanks guys,
Aran
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Have a search through the forum, all the answers are there!
Sorry, am new to the forum. Couldn't find any guides for these stickied though?...
Offline GTImike
  • Back in a Golf - Mk7 R
Simplest (possibly the only?) way for Highline is to change the whole clocks, get them coded by someone who knows what they are doing. Mileage and functionality can be problematic on earlier cars I think.
There's a set of R32 clocks with Highline in the for sale section at £185.00 at the mo.
The MFSW buttons, simple to fit IF you have DSG wheel/DSG car, usually just plug and play (although I had to code mine), if your car is a manual it is a lot harder, needs additional controllers.
The RNS 510 shouldn't pose too many problems if yours is an Eddy, earlier cars can suffer from battery drain issues to due to some CAN gateway issue. I'm no expert so best pm'ing someone like Eddie-NL who will be able to assist no doubt.
2008/58 Tornado Red Edition 30 (No. 1853) 5dr DSG - Gone but never forgotten
2017/66 Tornado Red Golf R 5D - Lasted 6 months before being sold on
Still have a TFSI in the family - 2009/59 Audi S3 8P facelift Stage 2 tuned
Oh and a Mk1 Golf GTI cabriolet
Offline tonto83
Can all be done but will cost you.
Mfsw £200-250
Controller £80
Airbag loom £30
Highline clocks £150-200 plus whatever to code them (talk to Kalu)
Rns510 £500-600 depending on which variant you choose.
May need a newer canbus to prevent battery drain, if your car is '08 and newer I think you'll be ok.
Talk to Kalu and if he lives within driving distance it wouldn't be much of an issue to fit highline clocks.  He can do 974 clocks.
Eddie nl sells the controllers, rns510, etc.
Both guys are super knowledgeable and great to deal with.
Personally I wish I had bought a car with highline clocks at least.
thanks fort he info guys.
Will I really need a new controller and airbag loom if the car is post 2008?
Offline RSam84
If you are not dsg, you will need the loom as you need a full new wheel. My brother needed a new controller on his 58 golf but that might have been for cruise control mainly
ahh, well I shall be looking for a DSG, so guess i'm ok there
Offline Squeeguk
Even with my 2008 Jetta with DSG and cruise, I had to fit a new steering controller and loom. Best off checking which controller you have with VCDS to make sure.
ok, thanks, i'll do that. What controller do I want? I'll need to check when I go to view the car
Offline Squeeguk
Re: Are these hard to fit? multi-func steering wheel; highline cluster; satnav?
« Reply #10 on: December 18, 2012, 05:28:35 pm »
Here is all the info you need regarding MFSW retrofit:
http://www.myturbodiesel.com/1000q/a5/paddle-shifter-steering-wheel-swap.htm
Hope this helps?
