Author Topic: PCV airflow  (Read 958 times)
Offline jimmy-s3
PCV airflow
« on: December 18, 2012, 05:49:51 pm »
Should air be getting sucked in from the small hole at the top of the PCV when the car is running?
If not, does this indicate a failed PCV?
Offline 56OctyVRS
  • -Receive: 72
Re: PCV airflow
« Reply #1 on: December 18, 2012, 07:49:45 pm »
The pcv is sealed unit and only recirculates intake and boost pressure from internally. It shouldnt suck or vent air to the atmosphere. Have you replaced it recently?
Offline jimmy-s3
Re: PCV airflow
« Reply #2 on: December 18, 2012, 08:09:34 pm »
Its never been replaced.
The car is an Ed30 with 47k. Im tyring to find out where a high pitched air squeal is coming from and when looking found the dome on the PCV to be drawing air in quite bad...Im not sure why the dome has a moulded outlet on it?
Ive plugged the hole up for now but the car is still making the high pitced air noise, but i cant locate where its coming from?
When i switch the car off the noise appears for about 2-3 seconds as if its releasing air pressure from somewhere?
