November 16, 2024, 01:59:52 pm
All Things Mk5
Mk5 General Area
Clutch change - What should you do at the same time?
Topic: Clutch change - What should you do at the same time? (Read 1106 times)
Mk5 GTian
Just look at my post count
-Given: 62
-Receive: 37
Wolfsburg - Probably the Best Cars in the World
December 21, 2012, 09:33:57 am »
I read on a thread recently that whilst you are changing your clutch there was something else you should do to save on labour, or it might have been the other way round, i.e. you are changing something and might as well do the clutch as well?
jimk04
Always Involved
-Given: 12
-Receive: 15
Re: Clutch change - What should you do at the same time?
Reply #1 on:
December 21, 2012, 09:54:46 am »
Slave cylinder....release bearing.....crankshaft oil seal.....gearbox input shaft seal?!
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
E30Dom
-Given: 42
-Receive: 76
Reply #2 on:
December 21, 2012, 09:55:29 am »
Limited slip diff... Well I wish I had done!
Diesel Daily Hack.
Mk5 GTian
-Given: 62
-Receive: 37
Reply #3 on:
December 21, 2012, 10:07:41 am »
Quote from: E30Dom on December 21, 2012, 09:55:29 am
Thanks Dom, so I might as well just go Stage 2, not Stage 2 plus, and save the clutch change for later down the road when I can afford a Quaiffe diff, then go 2+? (I have a lot of other mods to do before the diff, and the clutch is fine at the moment)
So build plans should look like this:
http://www.mk5golfgti.co.uk/forum/index.php/topic,49793.msg570673.html#msg570673
Last Edit: December 21, 2012, 10:12:16 am by Mk5 GTian
Gazza747
Always Involved
-Given: 15
-Receive: 16
Reply #4 on:
December 21, 2012, 11:14:14 am »
dual mass flywheel (DMF)
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
berg
-Given: 49
-Receive: 38
Reply #5 on:
December 21, 2012, 11:17:24 am »
lsd, slave cylinder
All Things Mk5
Mk5 General Area
