Author Topic: Beeps  (Read 3445 times)
Ifti
Beeps
« on: July 02, 2009, 09:43:42 am »
Around 2 weeks ago I started my car as normal, and got 4 quick, short beeps.
Nothing on the highline display.
No error lights etc.
Everything else was normal. The car still started perfectly fine and drove as per normal. So I ignored it.
Ever since then its been fine etc
Yesterday I had the same again when I started the car - but this time I think it was 5 beeps.
Nevertheless everything still starts and works as normal.
Today again, its been perfectly fine - no beeps at all.
Seems to just be random.
Any ideas?
Re: Beeps
« Reply #1 on: July 02, 2009, 09:49:56 am »
i had a similar thing, turned out to be my phone connecting automatically via bluetooth to the headunit when i switched the ignition on, also beeps when i turn the car off and the phone disconnects. took me ages to work it out  :ashamed:
doesnt sound like the same thing but thought i would put that out there
Ifti
Re: Beeps
« Reply #2 on: July 02, 2009, 01:01:56 pm »
I do have a Parrot Bluetooth - but that makes a completely different noise when connecting to it.
Im not too concerned with the beeps, since everything seems to be working normally. Just wondered what they were!
Re: Beeps
« Reply #3 on: July 02, 2009, 02:04:02 pm »
Is it a warning sound to notify you of a fault/misfire with the alarm system? Is the red LED on the door flashing when you disarm the alarm and open the door?
Just a thought?  :chicken:
Ifti
Re: Beeps
« Reply #4 on: July 02, 2009, 03:09:53 pm »
Yup, red light on door flashes when alarmed as normal.
I know the alarm is working, as I left my daughter in the car as I went to pay for the fuel the other day, since the car was cool after the air con had been on. I always lock the car when I go to pay for the fuel.
I came back to the alarm going off!
So Im pretty sure the alarm is working.....
Re: Beeps
« Reply #5 on: July 02, 2009, 09:02:32 pm »
Yeh but what Im saying is if the alarm has fired without you knowing and then been left before you return it may beep to tell you it has been set off?
Ifti
Re: Beeps
« Reply #6 on: July 02, 2009, 10:27:26 pm »
The first time it happened, the car was in my garage overnight, as always. I would have heard the alarm if it had of gone off.
The second time it happened - the 5 beeps - I was in traffic on the M11.
I was stationary for quite a while so I turned the engine off and sat in the car for a while.
I didnt lock the car obviously, as I was still in it!
About 5 mins later, when the traffic started to move I started the car up, and then got the 5 beeps.
No warning lights etc on either occasion. Nothing else to show anything is wrong. And as stated above, both times the car still starts and drives normally.
Re: Beeps
« Reply #7 on: July 02, 2009, 10:28:45 pm »
haunted.
fact.
call a priest
:chicken:
...and a weird little old lady with a dodgy accent
 :grin:
Re: Beeps
« Reply #8 on: July 02, 2009, 10:29:39 pm »
 :signLOL:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Beeps
« Reply #9 on: July 02, 2009, 10:30:26 pm »
Did you have anything on the passenger seat, it might have been the seat belt warning but would have thought you would have seen the symbol on the display cluster  :confused:
Ifti
Re: Beeps
« Reply #10 on: July 02, 2009, 10:36:36 pm »
Nope, nothing on seats.
No warning lights.
Exorcism??
Re: Beeps
« Reply #11 on: July 02, 2009, 10:45:02 pm »
Exorcism.
 :grin:
« Last Edit: July 02, 2009, 10:59:59 pm by Very Cherry »
Re: Beeps
« Reply #12 on: July 03, 2009, 10:30:11 am »
im tempted to say its something wrong with the alarm.
does the car beep so many times to tell you the alarm has gone off?
like it the left door has been opened it beeps 3 times
if the tilt sensor has gone off it beeps 4 times.
those arent accurate, just as an example of what the alarm does?
Ifti
Re: Beeps
« Reply #13 on: July 03, 2009, 10:36:58 am »
Im 100% sure that its not telling me the alarm has gone off.
As I said above, I turned the car off for 5 mins - didnt even remove the key - and then turned it back on, one day when I was in traffic, and I got 5 beeps.
Its very random, but hasnt happened in the past few days at all.
I think I need that Exorcist.
Will holy water damage my paintwork?
And is it unreasonable to ask the priest to wipe the water off after he's done??
Re: Beeps
« Reply #14 on: July 03, 2009, 12:16:30 pm »
from what i remember you will need to bless the car too and vomit bags are a must
the engine heads might start spinning etc etc so i would let the pro's go for it
...although
 :jumpmove:
