Author Topic: MFD & MFSW Not Working with RNS 510?  (Read 4022 times)
Offline AaronMc
« on: December 22, 2012, 01:14:06 pm »
Installed it yesterday, a straight swap for the RCD 510 that was put in by the previous owner.
All works spot on except the track up and down buttons dont work on the steering wheel, and also have nothing on the MFD relating to track names or anything?
Activated the Sat Nav in VAS PC at work today, but not sure what else needs doing? Any ideas or someone local with VAG COM would be great, im in West Sussex?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: MFD & MFSW Not Working with RNS 510?
« Reply #1 on: December 22, 2012, 05:10:00 pm »
Think it just needs coding in
Offline AaronMc
« Reply #2 on: December 22, 2012, 06:02:46 pm »
Hopefuilly thats all as I love having it appear on the dash and using the buttons..
Anyone in West Sussex able to help?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: December 25, 2012, 11:12:33 pm »
as you work for vw surely you should manage this simple task :signLOL:
Always makes me laugh when I get phone calls from vw master techs asking me about coding
Cluster and Key coding
Location Great Yarmouth
Offline AaronMc
« Reply #4 on: December 26, 2012, 07:19:41 am »
Only been there a few weeks so it's all still new to me at the moment. Am I right that I need to go on to channel 37, and disable or enable it and reboot the rns510?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: December 26, 2012, 10:49:02 am »
I would say that BAP and shortpress are ticked on the RNS510, so they need to be unticked
00000400040000200000
000004000400002000
try either of the above depending on which version of rns you have
reboot the RNS after coding
make sure navigation is added to the gateway
« Last Edit: December 26, 2012, 10:53:18 am by Eddie-NL »
Offline AaronMc
« Reply #6 on: December 26, 2012, 11:14:09 am »
As im using VAS PC at work thought its different software to VCDS.
But im sure I can sort that somehow, or i'll find a car audi place local to me who has VCDS.
I have added Nav to the Gateway, but didnt realise I would have to do any other coding.
« Last Edit: December 26, 2012, 11:17:08 am by AaronMc »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: December 26, 2012, 11:21:02 am »
you can use VAS to code it
Go into radio with VAS and see how long the coding is
then use the coding above depending on how long your coding is
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: December 26, 2012, 11:27:08 am »
BAP with Shortpress is
00000402040000810000
BAP only
00000402040000A00000
Offline RSM1
« Reply #9 on: January 10, 2013, 05:42:03 pm »
BAP only
eddie...
as always mate..your a master! :drinking:
