Author Topic: Fitting iPod vw kit information needed  (Read 983 times)
Offline Kemnaychris
« on: December 22, 2012, 06:40:25 pm »
Hi just bought the plug n play vw iPod kit
I plugged n played but nothing happening :(
Read the book and says take out brown wire from black terminal cars loom and put brown wire from iPod kit into it and put the wire fron car into iPod loom and click together
Would that be right in doing it and it will work?
Getting a terminal removal tool after Christmas to do this but was wondering if anyone else had to do this
It's a rcd 300 stereo
Any help would be ace cheers :)
2005 blue gray 140 gt tdi
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Fitting iPod vw kit information needed
« Reply #1 on: December 22, 2012, 06:42:26 pm »
it won't work till it has an earth, you can use another one
Cluster and Key coding
Location Great Yarmouth
Offline Kemnaychris
« Reply #2 on: December 22, 2012, 06:45:40 pm »
I assume the earth is this brown wires?
Offline andybon
« Reply #3 on: December 22, 2012, 07:03:41 pm »
Try touching it on the back of the radio. The one I have in mine just required the small screw taking out the back, A wire wrapping around it and it worked.
How hard can it be?
Offline Kemnaychris
« Reply #4 on: December 22, 2012, 07:58:09 pm »
Cool cheers but is brown the earth?
What wire do I earth ?
Getting bit confused now lol
As there 2 brown wires that come out the iPod wire
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: December 22, 2012, 10:16:29 pm »
if you add a smal bit of wire to the brown wire and attach it to the radio or dash frame that will be ok
I fitted one a while back, it only works when it has an earth
Offline Kemnaychris
« Reply #6 on: December 22, 2012, 10:28:20 pm »
Cool mate :) so the brown wire with the female clip don't touch and the wire that is lose just earth it is that correct?
And not bother with the male clip at all?
As u can see am useless with wires lol just always read the instructions u see :)
If I wire it up the way vw say would it work perfect ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: December 22, 2012, 10:32:00 pm »
You can wire it up how the vw instruction are listed but you must follow it 100%
or you can add a bit of wire to the brown wire and find an earth on the radio case or dashboard mount
Offline Kemnaychris
« Reply #8 on: December 23, 2012, 12:06:41 pm »
Legend cheers will get on it after Christmas :)
Got massive issues just now with car so the iPod can wait lol
Cheers for info dude will try both ways :)
