Author Topic: Strut braces?  (Read 5479 times)
Offline Polo6n1600i
Strut braces?
« on: December 24, 2012, 11:32:11 am »
With my Fabia I had an upper front strut brace, and an upper rear one. Now I'm not sure how much flex the mk5/jetta shell has, but are these worth doing?
I've seen the Tomas rear ones which look pretty cool - I have a jetta, but its still got the same rear seats, so in theory it should still fit?
And I've seen the lower subframe & centre bars. What's the deal with all these?
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Strut braces?
« Reply #1 on: December 25, 2012, 04:38:13 pm »
Have a search for the Unibrace. RedRobin has done some good reviews on both.
There is no point in a strut brace on PQ35 chassis cars. The bulkhead is so close to the struts they're not meant to add any additional rigidity
PLANS: Stage 2+
Offline Bignod00
  • Ginsters are sh*tE!!
Re: Strut braces?
« Reply #2 on: December 25, 2012, 04:43:56 pm »
I'm currently looking at purchasing the UNIbrace UB & XB, they're amazing bits of kit and so well made its untrue! :happy2:
Re: Strut braces?
« Reply #3 on: December 25, 2012, 07:42:39 pm »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Strut braces?
« Reply #4 on: December 31, 2012, 03:19:59 am »
Take a look at the engine bay and you'll see a similar 'connection' between both struts.
If you feel a need (track the car, run a super stiff suspension) then on a hatch consider
a rear brace. The Jetta won't even need this as its glued in rear window stiffens the rear.
BTW, there a 100 other things to do first.
"You get what you pay for."
Offline El1M1N8OR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=r42mcr2dbobrqade8s6ujcctvl&/topic,127700.msg1139562.html#msg1139562
Re: Strut braces?
« Reply #5 on: June 08, 2019, 12:05:48 pm »
How straight forward is fitting one of these braces?  I would refer to the one that goes into the vehicle cabin behind the rear seat.
Does it fit in directly without any modifications?
Re: Strut braces?
« Reply #6 on: June 15, 2019, 01:04:20 am »
MK5 doesn't need any bracing, front or rear.  You can't brace the rear without welding anyway due to the spring and damper mounting points.  The best way to make a MK5 hatchback as stiff as it can be is to weld in a Jetta rear seat bulkhead.
