Author Topic: High torque GTI  (Read 3792 times)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: High torque GTI
« Reply #15 on: December 25, 2012, 08:11:59 pm »
mine came up with more torque than a lamborghini aventador on the awesome dyno = dont use their dyno as it clearly is fooked, ie 400lb ft is not possible out of a ko4 on 2+, might be if running water meth?
James got 450lb ft on JKM's - that was K04 mapped to WMI
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
Re: High torque GTI
« Reply #16 on: December 25, 2012, 09:13:17 pm »
MK2 PRE-FL SEAT LEON TFSI SPORT - APR K04
Re: High torque GTI
« Reply #17 on: December 25, 2012, 09:23:32 pm »
270-315 lbft is the very most you can get out of a K03  :happy2:
K03 Stage 2 (Revo)................
Offline Shabba168
Re: High torque GTI
« Reply #18 on: December 25, 2012, 09:42:21 pm »
Revo stage 1 on JKM rollers 320lb-ft
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: High torque GTI
« Reply #19 on: December 25, 2012, 09:45:19 pm »
I'd better change my post Robin  :grin:
Re: High torque GTI
« Reply #20 on: December 25, 2012, 09:56:24 pm »
....Why? - I'm plotting < ~320 ftlb on Stage 2 and Shabba is < ~320 ftlb on Stage 1 (my B/F/T settings are turned down and his are probably turned up).
Offline zerolag
  • Ass of Ennis
Re: High torque GTI
« Reply #21 on: December 25, 2012, 10:11:10 pm »
265 from a stage1 on k03!?  what sort of boost is the K03 running to get that... Wow, I bet the EGT's are well high, ouch.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: High torque GTI
« Reply #22 on: December 25, 2012, 10:18:35 pm »
Oops I misread the scale  :laugh:
« Last Edit: December 26, 2012, 04:48:01 pm by GrayMK5GTI »
Offline PDT
  • -Receive: 142
Re: High torque GTI
« Reply #23 on: December 26, 2012, 11:08:42 am »
I have used dynojet dynos before and got high torque figures, it's caused by the incorrect RPM calibration. It also means mid range BHP is way out of scale.
Re: High torque GTI
« Reply #24 on: December 26, 2012, 12:27:13 pm »
....Am I right in thinking that it's down to the dyno operator to correctly calibrate the RPM?
Offline Shabba168
Re: High torque GTI
« Reply #25 on: December 26, 2012, 12:47:31 pm »
That was before I fitted down pipe so was still running precat when it was on the rollers.
I was running B7 F9 T6
Haven't had it on rollers with new settings and hardware
Now B9 F9 T5
Re: High torque GTI
« Reply #26 on: December 26, 2012, 12:59:59 pm »
....At JKM I was, and still am, running B7 F7 T5
Re: High torque GTI
« Reply #27 on: December 26, 2012, 01:26:25 pm »
 :smiley:
Re: High torque GTI
« Reply #28 on: December 26, 2012, 03:41:00 pm »
Whose VRS is that then, Hedge? I see it was back in 2008, so I guess it might have been 'muckipup' Dave.
Offline PDT
  • -Receive: 142
Re: High torque GTI
« Reply #29 on: December 26, 2012, 05:00:09 pm »
It's different on different dynos, some use an inductive pickup, others use OBD data, some require the operator to input the RPM tachometer details.
If its out by just a few MPH per RPM it can massively under/over read.
