Author Topic: Changing steering wheel spoke cover thingies.....  (Read 3567 times)
Ifti
« on: July 03, 2009, 10:38:22 am »
A friend of mine has the standard steering wheel - not a MFSW.
He wants to change the plastic covers on the two side spokes.
Is this a matter off simply unclipping the old and clipping on the new, or is there a little more detail to follow?
Re: Changing steering wheel spoke cover thingies.....
« Reply #1 on: July 03, 2009, 10:42:41 am »
i think what your referring to is the bit where the buttons go?
there are covers available for that i think
« Reply #2 on: July 03, 2009, 11:12:06 am »
That is correct, they just clip on and off matey  :happy2:
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #3 on: July 03, 2009, 03:41:08 pm »
Is it possible to fit the MFSW controls in this manner? I have a DSG steering wheel without MF and would like it but dont want to pay hundreds for another wheel.
If so, anyone got the part numbers and know everything required to do the job?
Edit: Misunderstood the OP. Thought he wanted to fit MFSW controls.
« Last Edit: July 03, 2009, 03:52:23 pm by Deako »
#1493
« Reply #4 on: July 03, 2009, 03:48:45 pm »
hmmm..if these just ping off i might spray mine candy
Offline BeezerDiesel
  • -Given: 33
« Reply #5 on: July 03, 2009, 04:18:28 pm »
On a non-MFSW the side clips are just plugged into a rubbery compound that fills the spoke. Prise them off carefully and slowly and they will pop out easily enough. If you tug them out too violently the rubber splits a bit.
On a MFSW the side clips housing the buttons are fitted differently and the spokes are hollow so you can't fit the buttons to a non-MFSW.
I've had both types of steering wheel in my time and have photos of them in bits if anybody needs to see the differences (assuming I can find them on my C drive).
Andy
7R
Offline big al
« Reply #6 on: July 03, 2009, 04:46:27 pm »
How would you spray them? is it just a simple spray can, or do you need to sand it and all that?
Previous owner of my GTI looked to have been a smoker, and there are slight spots where fag ash has caused the plastic to rise, so would love to do something like that to mine, save buying a new pair.
« Reply #7 on: July 03, 2009, 05:19:36 pm »
yup sanding, plastic primer, paint and laquer
might do it this weekend
Offline big al
« Reply #8 on: July 03, 2009, 05:50:35 pm »
And where would you get these from? and how do you apply them? getting really tempted now, maybe a silver to match the car.  :party:
« Reply #9 on: July 03, 2009, 06:38:16 pm »
paint is available from vw, £14 gets you a twin pack of vw colour matched paint and a tin of lacquer. plastic primer is available from halfrauds, next to the normal primer
if your doing silver then use a white primer, not grey or black and sand between coats. theyve very small (the trim) so should be hard to get wrong, if you do just sand it down. will take shots when i do mine  :happy2:
« Reply #10 on: July 04, 2009, 02:26:54 pm »
is there a trick to getting these off?  :confused:
mine are hanging on for dear life!  :grin:
  • -Given: 33
« Reply #11 on: July 04, 2009, 02:32:38 pm »
Wiggle and pull boy, wiggle and pull!!!! Work 'em out like a concrete turd
They need the very firm but gentle approach. Once you've got 'em out the first time it's much easier the second if that's any help to you  :laugh:
Andy
7R
« Reply #12 on: July 04, 2009, 02:38:27 pm »
so what you're saying is they're merely mocking me  :chicken:
i'm not standing for that...
  • -Given: 33
« Reply #13 on: July 04, 2009, 02:41:28 pm »
Attaboy!!! Wiggle and pull, wiggle and pull, deep breath, wiggle and pull, wiggle and pull......
Andy
7R
« Reply #14 on: July 04, 2009, 02:50:48 pm »
i might pad my face....
