Author Topic: Audio menu gone  (Read 5889 times)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Audio menu gone
« Reply #15 on: December 28, 2012, 11:09:11 am »
I'm sure that the polar is to blame here, the fact that the newer polar doesn't even require coding or fault clearing after fitting.
As there are several variations to the fusebox. The fuse for the instrument cluster is a 5A and is in the fusebox inside the car
Check the coding in the RCD510 that BAP has not been ticked, It might be worth trying your old rcd300
Cluster and Key coding
Location Great Yarmouth
Offline Baz300
Re: Audio menu gone
« Reply #16 on: January 01, 2013, 02:48:57 pm »
How can I check for BAP in the coding?
I can't seem to see anything about BAP when I am in the radios coding
Re: Audio menu gone
« Reply #17 on: January 01, 2013, 04:31:01 pm »
You need to look in the long coding helper and the check box for BAP is on one of the screens as you go throgh the coding
Offline Baz300
Re: Audio menu gone
« Reply #18 on: January 01, 2013, 04:39:00 pm »
I had a look through the long coding helper and didn't see BAP in any of the screens
Offline Baz300
Re: Audio menu gone
« Reply #19 on: January 01, 2013, 05:30:50 pm »
This is all I get in the radio long coding helper
Re: Audio menu gone
« Reply #20 on: January 01, 2013, 07:55:46 pm »
Not sure why but you should see this in byte 7 which you don't seem to have in your pic...   :confused:
NB this pic is with a RNS510
« Last Edit: January 01, 2013, 07:59:32 pm by bacillus »
Re: Audio menu gone
« Reply #21 on: January 01, 2013, 09:23:43 pm »
He has an RCD not an RNS.  :smiley:
Re: Audio menu gone
« Reply #22 on: January 01, 2013, 10:16:45 pm »
I pointed out that the pic was for a rns510 but the coding should be similiar for the rcd510 as I could see nothing related to navigation in that screen.
Offline Baz300
Re: Audio menu gone
« Reply #23 on: January 02, 2013, 12:05:33 pm »
That is in the navigation module though, I don't have NAV.
I have only been going through the radio module to get the coding.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Audio menu gone
« Reply #24 on: January 02, 2013, 12:23:16 pm »
On your units coding
The last digit is a 4, see if you can manually code that to a 2
