October 07, 2024, 05:26:46 am
All Things Mk5
Sat Nav and Car Audio
Sub and Amp
Topic: Sub and Amp (Read 1001 times)
JoeDarKa
Just look at my post count
-Given: 57
-Receive: 73
Sub and Amp
December 26, 2012, 05:27:01 pm »
Im looking at a sub and amp to fit into the enclosure from the GB. Iv found a sub that has 350w nominal power output (its a duel 2ohm coil) with a peak of 1200w. The amp im looking at is 1x400w rms at 2ohms with a peak at 800w. Will it run ok?
GT Sport - Reflex Silver 2.0 TDI
My Build
JoeDarKa
-Given: 57
-Receive: 73
Re: Sub and Amp
Reply #1 on:
December 29, 2012, 07:15:23 pm »
Bump, anyone?
My Build
screech
Always Involved
-Given: 1
-Receive: 7
Re: Sub and Amp
Reply #2 on:
December 30, 2012, 12:52:20 am »
What are the products you're looking at?
You won't get 4ohm load out of a dual 2ohm sub.
You'll need a 2ohm or 1ohm stable amp for that sub.
JoeDarKa
-Given: 57
-Receive: 73
Re: Sub and Amp
Reply #3 on:
December 30, 2012, 12:36:13 pm »
http://www.caraudiocentre.co.uk/product_m-jvc-ks-ax3101_p-26934.htm
http://www.caraudiocentre.co.uk/product_m-ts-w259d4_p-26815.htm
My Build
screech
Always Involved
-Given: 1
-Receive: 7
Re: Sub and Amp
Reply #4 on:
January 02, 2013, 09:32:00 pm »
That's a dual 4ohm sub - wire them in parallel to give a 2 ohm load.
That will then give 400wrms onto the 350rms sub. I wouldn't say no to that.
Sub looks good. Not personally a fan of JVC but don't think they have a bad name.
JoeDarKa
-Given: 57
-Receive: 73
Re: Sub and Amp
Reply #5 on:
January 02, 2013, 10:46:56 pm »
Sweet! There are other amps but just saw it, thought it looked ok.
My Build
All Things Mk5
Sub and Amp
