Author Topic: Parrot into a MK6 golf  (Read 7546 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=013e3414to1ovbq2jfi1n2sd54&/topic,19740.0.html
« on: December 26, 2012, 11:38:32 pm »
Hey up all.
When I installed a Parrot kit into a Polo 9n, i just used the supplied cables into the quad locks. Easy peasy.
Can i do the same with a Parrot kit in the MK6 golf, specifically the RCD210 radio as below?
Thanks in advance.
Rich
Re: Parrot into a MK6 golf
« Reply #1 on: December 27, 2012, 10:18:04 am »
Bump.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: December 27, 2012, 10:20:56 am »
should be the same as the other one, some you have to add a wire to a switched live
I'm surprised that you haven't upgraded the RCD210 to a 310 or better
Cluster and Key coding
Location Great Yarmouth
« Reply #3 on: December 27, 2012, 10:24:34 am »
Ta Eddie.
Not sure there's much to be gained from buying a rcd310.
Offline damoegan
« Reply #4 on: December 27, 2012, 11:09:16 am »
Yep, still plug and play, Rich  :happy2:
I recently fitted a Parrot kit to the Mrs' mk6 Golf without problems...
« Reply #5 on: December 27, 2012, 11:11:13 am »
Wonderful. Thanks again. I'm sick of Laura untangling iPhone headphones to take calls, it's only time before she has an accident.
Ill look forward to fitting it :-)
Offline damoegan
« Reply #6 on: December 27, 2012, 11:46:10 am »
Its easier to fit than in a mk5 as its much easier to remove the head unit. Think it only took me about 15-20 mins to remove head unit, fit Parrot and refit head unit  :signLOL:
« Reply #7 on: December 27, 2012, 11:53:22 am »
« Reply #8 on: December 27, 2012, 03:08:12 pm »
Why do you want to fit one of these?
« Reply #9 on: December 27, 2012, 06:58:09 pm »
Well i suppose if it were your car ian you would prefer a cockatoo.....  :chicken:
« Reply #10 on: December 27, 2012, 07:57:01 pm »
Touché.  :sad1:
« Reply #11 on: January 03, 2013, 07:22:28 pm »
Damo.....
So where the A and B plugs are... those will be disconnected and feed from the cig. socket?
Offline damoegan
« Reply #12 on: January 03, 2013, 07:33:47 pm »
Hmm, looking at that its just a plug and play mate..
The one's I have fitted are the ck3100, all had the same style bullet connectors for power just like un your diagram (note, you might need to swap red to orange of the unit does not power off when ignition is turned off) but still required a 12v connection (was a red lead)..
Can you take a pic of the wiring in the Parrot box?
Offline damoegan
« Reply #13 on: January 03, 2013, 07:36:32 pm »
Actually, now that I think about it, the 12v red lead that required connecting was off the adaptor that was required (car specific)
« Reply #14 on: January 03, 2013, 07:36:46 pm »
Not a useful one...
 :signLOL:
« Last Edit: January 07, 2013, 06:10:30 pm by richwig83 »
