Author Topic: Car running rough now with photos  (Read 5378 times)
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Car running rough
« Reply #15 on: January 16, 2013, 04:52:25 pm »
The follower will be replaced.
How many miles are on the car? Has it had an oil change every 10k miles?
'07 Red manual
Offline micaerin
  • -Given: 19
« Reply #16 on: January 16, 2013, 04:56:19 pm »
72000 full vw service history with long life oil
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
Offline 94Luke
« Reply #17 on: January 16, 2013, 04:59:07 pm »
This may have happened to your car then if they're saying a replacement camshaft is needed: http://www.mk5golfgti.co.uk/forum/index.php/topic,41330.0.html
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #18 on: January 16, 2013, 05:02:13 pm »
Are you running a hpfp?
This is real barstard - I have an '07 too and am trying to find the time to replace the follower. My dealer told me it wasn't an issue...http://www.mk5golfgti.co.uk/forum/index.php/topic,57710.0.html
'07 Red manual
Offline zerolag
  • Ass of Ennis
« Reply #19 on: January 16, 2013, 05:09:57 pm »
My dealer told me the same thing... the service manager didn't even know what I was on about - asked the lead mechanic, and he said he's never replaced one :stupid:  Doesn't fill you with much confidence.  Wouldn't even give me a price, said it would have to be a time based job... cough... fook that!
I think this must be a lot to do with dealers seeing newer cars, less than 3 years old, standard and less GTI's than other models, where problems with the Cam follower are few and far between.  Once the cars get older people seem to go to indy's who know a lot more about this problem.
Offline gigolo456
« Reply #20 on: January 16, 2013, 05:14:09 pm »
is the cam follower changed when changing the cam-belt do you know??
Offline Aas
« Reply #21 on: January 16, 2013, 05:21:40 pm »
 No
Offline micaerin
  • -Given: 19
« Reply #22 on: January 16, 2013, 05:23:00 pm »
Nope standard fuel pump, also i doubt this is changed when they do the cam belt as mine was done 18 months ago
Offline Jonnybear
« Reply #23 on: January 16, 2013, 05:23:29 pm »
Cam followers have had issues for years', just replaced camshaft and followers on pd. had a similar prob on GTI however fault only occurs when hot turn out to be hp pump breaking down.
Hope your car get sorted !
Offline micaerin
  • -Given: 19
« Reply #24 on: January 16, 2013, 05:24:42 pm »
Thanks, looks like ive learnt the hard way £1100  :indifferent: :sick:
Offline gigolo456
« Reply #25 on: January 16, 2013, 05:27:36 pm »
I would however get a 2nd opinion from an Independent Specialist, they would be cheaper if nowt else and would know what they're doing!! Where abouts are you???
Offline micaerin
  • -Given: 19
« Reply #26 on: January 16, 2013, 05:31:53 pm »
Too late its at VW now and all stripped waiting for new camshaft to be fitted tomorrow.
Just got off the phone with VW asking about the cam follower and was told it was the camshaft thats worn not the cam follower?
Offline gigolo456
« Reply #27 on: January 16, 2013, 05:37:48 pm »
Fair enough, but as a precautionary measure, id have yr cam follower changed as soon after as u can BY an Indie!
Offline micaerin
  • -Given: 19
« Reply #28 on: January 16, 2013, 06:55:49 pm »
They are going to replace it when they do the camshaft
Offline TopsGTI
« Reply #29 on: January 16, 2013, 08:21:48 pm »
I had the same problem at as you which only became apparent with the engine under high loading after I remapped it. I would ask them to keep your old camshaft so you can see the damage though  :happy2: Its generally the faulty cam follower which causes the wear to the camshaft lobe itself. When they removed mine the follower and cam lobe were both equally well worn. Had the DV done at the same time (which was split) and been running like a dream since  :smiley:
