Author Topic: RNS510 Update help request  (Read 1453 times)
Yargo
« on: December 28, 2012, 02:56:09 pm »
Hey,
I searched the internet but got no answer to my question.
First some info about my RNS-510:
HW-version: H42, SW-version: 1304 Delivery Part Number: 3T0035680A
Now my question is, to wich firmware can I safely upgrade without the need of a recode? Can I upgrade to 3814 safely?
Thanks!
Wes
Yargo
Re: RNS510 Update help request
« Reply #1 on: December 28, 2012, 04:14:31 pm »
Ok, I read some topics about RNS-510 firmware and this is my conclusion:
I can't go from a 1xxx firmware to higher than 268x firmware. So I have to upgrade to this version and then to 38xx? I cant go higher than 38xx without recoding? Or is there a modified version so recoding is not needed anymore?
« Last Edit: December 28, 2012, 04:19:19 pm by Yargo »
cannac123
« Reply #2 on: January 03, 2013, 10:26:01 pm »
Hi
Not sure if this helps you, but a couple years ago I fitted a RNS510 vers B unit HW04 firmware 1100 into my 05 GTI.
Not knowing what vers my canbus was, I suspected it would of needed changing, I played safe and installed modified firmware 2760/1200 and I've had no problems. (No Rosenberg syndrome and no battery drain)
Since then I haven't felt the need to update the firmware further. I've updated my maps as each new version has became available, version 7 with the updated firmware gave 7 digit postcode input, then vers 8 speed cams and I presently have vers 9 7920 maps with speed cams installed.
Offline MarkMarked
« Reply #3 on: January 06, 2013, 02:13:17 pm »
There are modified versions of 1300, 2760 and 3810 for the revision A, I don't think you go go any higher
Offline golfman
  • -Given: 17
« Reply #4 on: January 07, 2013, 07:06:12 pm »
How much are these RNS-510?
Send EddieNL a pm and he can sort u out with a price!!!
Scott :happy2:
Vag-com Hex+Can in scotland
I Hate Timewasters...
